Connection String problems when using a mirror / ASP2 site
I installed a forum based on ASP2 and using SQL2005 as database ...
The original web.config is
<configuration>
      <system.web>
            <identity impersonate="true" userName="mirror\sql" password="Spyware43" />
  <pages validateRequest="false" />
      </system.web>
      <appSettings>
            <add key="DatabaseString" value="Driver={SQL Server};Server=sql1.mirror.com;Database=forum;Trusted_Connection=yes;" />
            <add key="DatabasePrefix" value="DMG" />
            <add key="LongDateFormat" value="MMMM d, yyyy" />
            <add key="ShortDateFormat" value="M/d/yyyy" />
            <add key="DateTimeFormat" value="M/d/yyyy h:mm:ss tt" />
      </appSettings>
</configuration>
So I tried now to configure it using the mirror so I changed the string to
<add key="DatabaseString" value="Driver={SQL Server};Server=sql1.mirror.com; Failover Partner=sql2.mirror.com;Database=forum;Trusted_Connection=yes;" />
I also tried adding the ports as well ...
But the error I get is
Server Error in '/' Application.
ERROR [42000] [Microsoft][ODBC SQL Server Driver][SQL Server]Cannot open database "forum" requested by the login. The login failed.
ERROR [01S00] [Microsoft][ODBC SQL Server Driver]Invalid connection string attribute
When connecting to the website locally.
Remotely I get
Runtime Error
Description: An application error occurred on the server. The current custom error settings for this application prevent the details of the application error from being viewed remotely (for security reasons). It could, however, be viewed by browsers running on the local server machine.
Details: To enable the details of this specific error message to be viewable on remote machines, please create a <customErrors> tag within a "web.config" configuration file located in the root directory of the current web application. This <customErrors> tag should then have its "mode" attribute set to "Off".
Any help is highly appreciated
LVL 2
CassavatechAsked:
YveauConnect With a Mentor Commented:
So the issue is that you cannot connect to the mirror database ?
That is correct, that is only there for High Availability purposes. You cannot connect to it as long as it is the mirror.
When you want to 'automatically' failover the app as well, try:
<add key ="DatabaseString" value="Server=Server1;Failover Partner=Server2;Initial Catalog=forum;Trusted_Connection=yes;"></add>
Hope this helps ...
YveauCommented:
Did you create the user in the database forum and map it to the login you use to conenct ot the SQL Server ?
Hope this helps ...
CassavatechAuthor Commented:
Yes I did .. it is perfectly working when I just use one connection.
For example, I can failover the database, change the connection string to SQL2 (mirror) and the forum is working again. I fail it back over to SQL1 (principal), change the connection string accordingly and its all working fine again.
Hiya,
I tried that .. so the complete web.config would be
<configuration>
      <system.web>
      </system.web>
      <appSettings>
            <add key ="DatabaseString" value="Server=sql1.mirror.com;Failover Partner=sql2.mirror.com;Initial Catalog=forum;Trusted_Connection=yes;" />
      </appSettings>
</configuration>
As a result I get the error
ERROR [IM002] [Microsoft][ODBC Driver Manager] Data source name not found and no default driver specified
So when I add the driver as in the original web.config
<add key ="DatabaseString" value="Driver={SQL Server};Server=sql1.mirror.com;Failover Partner=sql2.mirror.com;Initial Catalog=forum;Trusted_Connection=yes;" />
I get the error
ERROR [42S02] [Microsoft][ODBC SQL Server Driver][SQL Server]Invalid object name 'DMG_SETTINGS'.
And it hasn't even failed over yet ....
YveauCommented:
the failover connection string only works for .net version 2 or higher ... do you have that ?
Yes it does run .net 2.0.50727
YveauCommented:
I noticed you use the SQL ODBC driver ... try using the native SQL Server connection. You probably need to install that first ... I do not know if the failover is supported by the ODBC driver ... come to think of it ... it probably is not ...
Just install the connectivity part of the SQL Server installation to the webserver.
Hope this helps ...
How would I have to change the connection string ?
YveauCommented:
The part
    Driver={SQL Server}
is not in my connection strings ... and it uses the native connection ... I think that could be it.
Not sure ...
Hope this helps ...
As I mentioned above ..if I don't use Driver=(SQL Server) etc. I get the error
YveauCommented:
it look slike you do not have the proper provider. Then the connection switches to ODBC, but there is no DSN on the system.
Try doing that and tell us what the error message is ... it might set us on the right track ...
Hope this helps ...
This was pretty much the right solution - I had a problem somewhere else too
YveauCommented:
Glad I could be of any help !
