G2intern
asp:menu populated from asp:dropdown using ajax.net problem
I have a dropdown that when selected, chooses which sitemap to bind my menu to. This is because each sitemap has a different set of permissions using the security model. I'm trying to use ajax.net so that when the dropdown selected index is changed, the menu populates without reloading the page. Its simple not doing it and the page refreshes every time. Anyone have experience with this?? Thanks so much
<asp:DropDownList ID="ddNavigation" AutoPostBack="true" runat="server" BackColor="White" Font-Names="verdana" Font-Size="X-Small" ForeColor="RoyalBlue" OnSelectedIndexChanged="ddNavigation_SelectedIndexChanged"
Width="170px">
<asp:ListItem Value="0">Home</asp:ListItem>
<asp:ListItem>Administration</asp:ListItem>
<asp:ListItem>Employees</asp:ListItem>
<asp:ListItem>Requirements/Attendance</asp:ListItem>
<asp:ListItem>Reports</asp:ListItem>
</asp:DropDownList>
<asp:UpdatePanel ID="UpdatePanel1" runat="server">
<ContentTemplate>
<asp:Menu ID="Menu1" runat="server" BackColor="RoyalBlue" Width="170px" DynamicHorizontalOffset="2" Font-Names="Verdana" Font-Size="X-Small" ForeColor="White" StaticSubMenuIndent="5px" StaticDisplayLevels="2"
Font-Underline="False" CssClass="menu">
<DynamicHoverStyle BackColor="MidnightBlue" ForeColor="White" />
<DynamicMenuStyle BackColor="RoyalBlue" CssClass="sublevel1" />
<DynamicMenuItemStyle HorizontalPadding="5px" VerticalPadding="2px" />
<StaticHoverStyle BackColor="MidnightBlue" />
</asp:Menu>
</ContentTemplate>
<Triggers>
<asp:AsyncPostBackTrigger ControlID="ddNavigation" EventName="SelectedIndexChanged" />
</Triggers>
</asp:UpdatePanel>
do you have a scriptManager control on your page?
I do have a script manager above this code, I just did not throw it in the code snippet. Sorry for that.
Thanks so much, I watched their introduction video on the ajax.net website, and it didn't mention the web.config added sections. Thanks so much!!
