David Megnin
Position RadioButtonList on right edge of window and keep text from overlapping it.
On a Web Form with lots of RadioButtonLists for "_Y _N _N/A" answers to questions I'm trying to position the RadioButtonLists in a straight column on the right edge of the window.
I have them positioned on the right edge okay like this
<style>
.ToRight{position:absolute ; right:10px;}
#container {padding-left:80px; padding-right:50px}
</style>
<asp:RadioButtonList CssClass="ToRight" ID="radTraining6Months" runat="server" RepeatDirection="Horizonta l" RepeatLayout="Flow" TabIndex="580">
<asp:ListItem>Y</asp:ListI tem>
<asp:ListItem>N</asp:ListI tem>
<asp:ListItem>N/A</asp:Lis tItem>
</asp:RadioButtonList>
The whole form is inside a <div id="container"></div>
The problem is that long questions will go to the 50px right edge before wrapping to the next line even if that makes the sentence overlap the RadioButtonList a bit.
I can move the right edge or margin of the questions over more by increasing the padding-right:50px to padding-right:100px or so, but that is not the effect I want.
I want want the text to wrap when it encounters the RadioButtonList so I can have the margins set to a reasonable width and still not overlap the RadioButtonLists.
I tried setting the margin-left and padding-left style of the RadioButtonList but that had no effect.
Any suggestions?
David
<style>
</style>
Any suggestions?
David
I tried floating the radio buttons, but they moved down to the next line. That just won't do. I think that adding a "width" attribute may help.
<style>
</style>
to
<style>
.ToRight{float:right}
</style>
causes the RadioButtonLists to appear a one line below the question and some of them to not line up all the way to the right. I had tried float first.
