sgh_aba
Need to add two PATs or NATs for incoming RDP using CLI (not PDM)
I have an in production PIX 506E, for a few years now, that has been working fine but I need to add through the CLI (PDM is not working for some reason) 2 PAT/NAT entries that will allow incoming tech support (64.100.100.1) to RDP (TS) into two different servers on the inside (private), 192.168.9.3 and 192.168.9.4 respectively. Currently using 65.100.112.2 (Public) for all outgoing HTTP(S) browsing as well as incoming VPN clients. This is working fine and I don't want to break any of this. I have available two more free Public addresses, 65.100.112.3 and 65.100.112.4, that I want to PAT/NAT into 192.168.9.3 and 192.168.9.4 and only allow RDP incoming from 64.100.100.1 to 64.100.100.5. I assme PAT is better for this, but perhaps NAT works too since I have the 1 to 1 connection.
thanks,
sgh_aba
thanks,
sgh_aba
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list inside_outbound_nat0_acl permit ip 192.168.9.0 255.255.255.0 192.168.200.0 255.255.255.224
access-list inside_outbound_nat0_acl permit ip 192.168.9.0 255.255.255.0 192.168.200.48 255.255.255.248
access-list outside_cryptomap_dyn_20 permit ip any 192.168.200.0 255.255.255.224
access-list outside_cryptomap_dyn_40 permit ip any 192.168.200.48 255.255.255.248
pager lines 24
logging on
mtu outside 1500
mtu inside 1500
ip address outside 65.100.112.2 255.255.255.248
ip address inside 192.168.9.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
ip local pool MYP1 192.168.200.1-192.168.200.29
ip local pool MYVP1 192.168.200.50-192.168.200.53
pdm location 192.168.9.252 255.255.255.255 inside
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 10 interface
nat (inside) 0 access-list inside_outbound_nat0_acl
nat (inside) 10 0.0.0.0 0.0.0.0 0 0
route outside 0.0.0.0 0.0.0.0 65.100.112.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http 192.168.9.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto dynamic-map outside_dyn_map 20 match address outside_cryptomap_dyn_20
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-MD5
crypto dynamic-map outside_dyn_map 40 match address outside_cryptomap_dyn_40
crypto dynamic-map outside_dyn_map 40 set transform-set ESP-3DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
isakmp enable outside
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption 3des
isakmp policy 20 hash md5
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
vpngroup MYG1 address-pool MYP1
vpngroup MYG1 idle-time 1800
vpngroup MYG1 password ********
vpngroup MYVG1 address-pool MYVP1
vpngroup MYVG1 idle-time 1800
vpngroup MYVG1 password ********
telnet 192.168.9.0 255.255.255.0 inside
telnet 192.168.200.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
terminal width 80
sgh_aba
