Solved
GPO Help - Need Help Locating and Changing A Custom Setting.
Posted on 2007-12-06
8
Last Modified: 2008-05-31
Hey everyone,
I've got a GPO that was made with Server 2000 and possibly created on XP SP1.  Now I've been given the task of changing it some what, but I can't tweak one of the settings.
We are looking to remove only the "C" drive from the user's "My Computer" on the network's workstations.
Inside of GPMC, I open the GPO and hit the Settings Tab...at the bottom of that tab I see:
Extra Registry Settings
     Display names for some settings cannot be found. You might be able to resolve this issue by updating the .ADM files used by Group Policy Management.
Setting        State
Software\Microsoft\Windows\CurrentVersion\Policies\Explorer\NoDrives         31
I think this is what I need to alter to allow all drive except the "C" drive.
Does anyone know how I might revert that back or view it so its NOT and "Extra Registry Setting?"
thanks,
inverted
Question by:inverted_2000
7 Comments
LVL 26
Expert Comment
by:Farhan Kazi
Have a look at following link:
http://support.microsoft.com/kb/231289
Hope this helps!
Farhan
LVL 2
Author Comment
by:inverted_2000
Kind of helps...but there are 70 folders under
\\server\SYSVOL\clt.domain.com\Policies\
I see the system.adm file, but which one should I access the system.adm from?
LVL 16
Expert Comment
by:2PiFL
Can you use the GPOE and follow these steps:
1. Start the Microsoft Management Console. On the Console menu, click Add/Remove Snap-in.
2. Add the Group Policy Object Editor snap-in for the default domain policy. To do this, click Browse when you are prompted to select a Group Policy Object (GPO). The default GPO is Local Computer. You can also add GPOs for other domain partitions (specifically, Organizational Units).
3. Open the following sections: User Configuration, Administrative Templates, Windows Components, and Windows Explorer.
4. Click Hide these specified drives in My Computer.
5. Click to select the Hide these specified drives in My Computer check box.
6. Click the appropriate option in the drop-down box.
This will edit the proper .adm file
Simplify Active Directory Administration
Administration of Active Directory does not have to be hard.  Too often what should be a simple task is made more difficult than it needs to be.The solution?  Hyena from SystemTools Software.  With ease-of-use as well as powerful importing and bulk updating capabilities.
LVL 2
Author Comment
by:inverted_2000
I got that much...I'm going to try to set them all back as Disabled and see if I can get them back to the default.
LVL 2
Author Comment
by:inverted_2000
Yup...I just changed the settings around...from:
Enabled
  to
Disabled
  to
Not Configured
That seemed to re-write whatever had that option 31 in place.
Thanks anyway folks (o:
LVL 86
Accepted Solution
by:
oBdA earned 2000 total points
The guy who did this probably did what Microsoft recommends *not* to do: he edited the %Systemroot%\inf\system.adm file on his machine, created the GPO, and the customized adm got updated by a service pack.
Make a backup of the GPO using the GPMC before you start with the following.
Use the GPMC to find the GPO's GUID; in the policies folder, check the subfolder named with this GUID for the subfolder "Adm". In the adm folder, open system.adm in Notepad, and search for "!!ABOnly" (can appear several times); check if you see the "31" (which hides A through E) as VALUE NUMERIC in this policy block.
If so, copy that system.adm to your workstation, rename it to system-temp.adm or whatever. Start the GP editor, unload system.adm (right-click "User Configuration\Administrative Templates"), load your system-temp.adm instead. You should now be able to set the "Hide Drives" policy back to "Not configured" (don't change anything else). Close the GP editor, open it again. Remove the system-temp.adm file, add the original system.adm, and you should now be able to set the "Hide Drives" value to your likings.
LVL 1
Expert Comment
by:modus_operandi
Force accepted.
modus_operandi
EE Moderator
Microsoft Office 365 is a subscriptions based service which includes services like Exchange Online and Skype for business Online. These services integrate with Microsoft's online version of Active Directory called Azure Active Directory.
Active Directory can easily get cluttered with unused service, user and computer accounts. In this article, I will show you the way I like to implement ADCleanup..
This Micro Tutorial hows how you can integrate  Mac OSX to a Windows Active Directory Domain. Apple has made it easy to allow users to bind their macs to a windows domain with relative ease. The following video show how to bind OSX Mavericks to …
There are cases when e.g. an IT administrator wants to have full access and view into selected mailboxes on Exchange server, directly from his own email account in Outlook or Outlook Web Access. This proves useful when for example administrator want…
578 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
