Visual Studio, and sharepoint web parts
R8VI
R8VI asked
on
Last Modified: 2013-11-26
have the following piece of code with all the references added. and the connection string stored in my web config file. I build the project and copy and paste the dll to the server where my sharepoint bin directory is. But when i load the web part the information retrieved from the database is not displayed.
I get the error message that I have pasted below the code.
Can someone please help and point out where i am going wrong. Any help is much appreciated thanks in advance
 public class WebPart1 : Microsoft.SharePoint.WebPartPages.WebPart
        //public int yourVar = 0;
        public class foo
           public static int yourVar;
       public static int GetYourDataObject()
            using (SqlConnection connection1 = new SqlConnection(System.Configuration.ConfigurationManager.ConnectionStrings["constring1"].ConnectionString))
                connection1.Open();
                using (SqlCommand command1 = new SqlCommand("SELECT COUNT(x) As COUNTVAR FROM table", connection1))
                     foo.yourVar = Convert.ToInt32(command1.ExecuteReader());
                    return foo.yourVar;
        protected override void RenderWebPart(HtmlTextWriter output)
           foo.yourVar = GetYourDataObject();
            output.Write(@"</BR><span style='font-size:10pt;'>Display the number: </span>");
            output.Write(@"<span style='color:#61AE09; font-size:11pt;'>" + foo.yourVar + "</span></BR>");
Error Message in Sharepoint
An error occured when previewing the Web Part.   at Microsoft.SharePoint.WebPartPages.WebPartPreview.Render(HtmlTextWriter writer)
   at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter)
   at System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter)
   at System.Web.UI.Control.RenderControl(HtmlTextWriter writer)
   at ASP._layouts_wpprevw_aspx.__Render__control9(HtmlTextWriter __w, Control parameterContainer)
   at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children)
   at System.Web.UI.Control.RenderChildren(HtmlTextWriter writer)
   at System.Web.UI.Control.Render(HtmlTextWriter writer)
   at System.Web.UI.HtmlControls.HtmlForm.RenderChildren(HtmlTextWriter writer)
   at System.Web.UI.HtmlControls.HtmlForm.Render(HtmlTextWriter output)
   at System.Web.UI.HtmlControls.HtmlForm.RenderControl(HtmlTextWriter writer)
   at System.Web.UI.HtmlControls.HtmlContainerControl.Render(HtmlTextWriter writer)
   at Microsoft.SharePoint.WebControls.UnsecuredLayoutsPageBase.RenderChildren(HtmlTextWriter writer)
   at System.Web.UI.Page.Render(HtmlTextWriter writer)
   at Microsoft.SharePoint.WebControls.UnsecuredLayoutsPageBase.Render(HtmlTextWriter writer)
   at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
Watch Question
Just out of interest replace
with this
using (SqlConnection connection1 = new SqlConnection("Your actual connection string not a reference"))
Could you tell me if this works like this.  I do not propose to keep it like this, just want to dig a little deeper.
Andrew
I have tried that and still get the same error that I have pasted before.
Were am i going wrong.
try this now to test:
Andrew
           base.RenderWebPart(output);
           //foo.yourVar = GetYourDataObject();
           // output.Write(@"</BR><span style='font-size:10pt;'>Display the number: </span>");
           // output.Write(@"<span style='color:#61AE09; font-size:11pt;'>" + foo.yourVar + "</span></BR>");
This is what is shown
This is a preview of the Web Part. To use this Web Part, open a Web Part Page and then add this Web Part from the ToolPane.
The name of the solution. none of the output is shown as it is commented out
Thanks Again
Create a usercontrol and add this usercontrol to the webpart.
           YourCustomControl custom1 = new YourCustomControl();
           Controls.Add(custom1);
Sorry about this but i am confused now
I replaced my code with ur last code and have these errors
Error      1      The type or namespace name 'YourCustomControl' could not be found (are you missing a using directive or an assembly reference?)
Error      3      The best overloaded method match for 'System.Web.UI.ControlCollection.Add(System.Web.UI.Control)' has some invalid arguments
Error      4      Argument '1': cannot convert from 'YourCustomControl' to 'System.Web.UI.Control'
Explore More ContentExplore courses, solutions, and other research materials related to this topic.
