Mehram
To break a string into several parts
SQL 2000
declare @a varchar(100)
set @a = '6125.349.5601.278.90.blac k.blue'
The variable @a hold seven different values seperated by '.'
I have a table where a column holds data whoose pattern is exactly like above.
Now I want to break the abve value into seven different columns.
Like
value1=6125
value2=349
value2=5601
value4=278
value5=90
value6=black
value7=blue
All the values should be shown in one row.
Is it possible to do this without using function?
Is it possible to do through select statement?
I want to update the table having columns value1,value2, value3,value4,value5,value 6,value7
MTNN
Like
value1=6125
value2=349
value2=5601
value4=278
value5=90
value6=black
value7=blue
MTNN
declare @sInputList varchar(100)
set @sInputList = '6125.349.5601.278.90.blac k.blue'
DECLARE @Item Varchar(8000)
declare @Delimiter varchar(1)
declare @cnt int
set @Delimiter = '.'
set @cnt = 1
WHILE CHARINDEX('.',@sInputList, 0) <> 0
BEGIN
SELECT
@Item=RTRIM(LTRIM(SUBSTRIN G(@sInputL ist,1,CHAR INDEX(@Del imiter,@sI nputList,0
)-1))),
@sInputList=RTRIM(LTRIM(SU BSTRING(@s InputList, CHARINDEX( @Delimiter ,@sInputLi st,0)+1,LE N(@sInputL ist))))
IF LEN(@Item) > 0
print '@col' + convert(varchar(1),@cnt)+ '=' + @Item
set @cnt = @cnt + 1
end
print '@col' + convert(varchar(1),@cnt)+ '=' + @sInputList
declare @cnt int
set @cnt = 1
BEGIN
SELECT
)-1))),
IF LEN(@Item) > 0
set @cnt = @cnt + 1
end
try this
SELECT * FROM urTable
WHERE (CAST(column1 AS VARCHAR(20)) + '.' +
CAST(column2 AS VARCHAR(20)) + '.' +
CAST(column3 AS VARCHAR(20)) + '.' +
CAST(column4 AS VARCHAR(20)) + '.' +
CAST(column5 AS VARCHAR(20)) + '.' +
CAST(column6 AS VARCHAR(20)) + '.' +
CAST(column7 AS VARCHAR(20))) = @a
I am getting the result in the shape of array.
I am having
6125
349
5601
278
90
black
blue
into single variable/column.
I want to have like
@col1=6125.@colb=349,@clc=
