problem with dblink between MS SQL 2000 32 bits and 2005 64 bits
Hello guys,
someone knows if there is any problem to work with 32 and 64 bits MS SQL plataform ???
I have in one server MS SQL 2000 32 bits and in other MS SQL 2005 64 bits,
When I test the connection I get ok
but when I try to run a query I got an error.
is there any incompatibility between them?
this is the error message
OLE DB provider "SQLNCLI" for linked server "BDCARAJAS" returned message "Unspecified error".
OLE DB provider "SQLNCLI" for linked server "BDCARAJAS" returned message "The stored procedure required to complete this operation could not be found on the server. Please contact your system administrator.".
Msg 7311, Level 16, State 2, Line 1
Cannot obtain the schema rowset "DBSCHEMA_TABLES_INFO" for OLE DB provider "SQLNCLI" for linked server "BDCARAJAS". The provider supports the interface, but returns a failure code when it is used.
thanks
LVL 1
hidrauAsked:
EE_AutoDeleterConnect With a Mentor Commented:
netrep,
Because you have presented a solution to your own problem which may be helpful to future searches, this question is now PAQed and your points have been refunded.
EE_AutoDeleter
hidrauAuthor Commented:
I found a solution
http://support.microsoft.com/kb/906954
thanks anyway
