Avatar of nairski
nairski
Motherboard Reset Switch/Power Switch/LED Extension Cable - 2-pin female to 2-pin female
Hi everyone,
I'm building a mini itx pc - EPIA EN series, custom case, pico psu.
I'm trying to find some Motherboard Reset Switch/Power Switch/LED  Extension Cable - 2-pin female to 2-pin female cables or am happy to make them (get the connectors and fit cables)
Similar to this item..
http://www.frozencpu.com/products/1836/ele-188/FrozenCPU_Standard_Motherboard_Reset_Switch_Extension_Cable.html?tl=g35c34s319&id=iyI72zuX
However with both ends being female.
Has anyone come across this type of item, i've tried Maplins.
Avatar of f-king
f-king
Flag of Portugal image
doesnt the case come with these connectors?
Avatar of nairski
nairski
I got case free. Unfortunately, the case has the pins(for LED and Power Switch) but no cables to connect back to the motherboard.
could get switch with cable;
http://www.directron.com/atxswitch.html
Avatar of nobus
not sure if this is waht you need :  http://www.orbitmicro.com/global/standardmotherboardresetswitchextensioncable-p-5688.html
i just cut the wires, and solder the cable length in between
Avatar of nairski
nairski
