Avatar of KenTan85
KenTan85 asked on
Problem with using PrintWriter inside a JSP
I have a JSP where i try to print a XML data.
After the Jsp executes, I see only the data in the screen. I should see a table along with the data(tables are defined in the XSL file).
Same code works when we use PrintWriter from with in the servlet.It didnt work inside a JSP.
Please suggest me what i am missing.
PS: I cannot create xml file and use transformation as i need to have pagination on the html page...
JSP Code:
PrintWriter out= response.getWriter();
out.write("xml version='1.0'?><?xml-stylesheet type='text/xsl' href='book.xsl'?><students> <student><name>Thomas</name><place>Delhi</place> <number>1111</number> <mark>78</mark></student>></students>"")
XSL Code:
XSL file is below : <?xml version="1.0"?>
<xsl:stylesheet xmlns:xsl="http://www.w3.org/1999/XSL/Transform" version="1.0">
<xsl:template match="/">
<html>
<body>
<table border="2" bgcolor="yellow">
<tr>
<th>Name</th>
<th>Place</th>
<th>Number</th>
<th>Mark</th>
</tr>
<xsl:for-each select="students/student">
<tr>
<td><xsl:value-of select="name"/> </td>
<td><xsl:value-of select="place"/> </td>
<td><xsl:value-of select="number"/> </td>
<td><xsl:value-of select="mark"/> </td>
</tr>
</xsl:for-each>
Web Languages and StandardsJSP
rrz
rrz
I corrected the errors.  Please ask if you have any follow up questions.
out.write("<?xml version='1.0'?><?xml-stylesheet type='text/xsl' href='book.xsl'?>" +
          "<students> <student><name>Thomas</name><place>Delhi</place>" +
          "<number>1111</number> <mark>78</mark></student></students>");
<html>
<body>
<tr>
<th>Name</th>
<th>Place</th>
<th>Number</th>
<th>Mark</th>
</tr>
<tr>
</tr>
</xsl:for-each>
</table>
</body>
</html>
</xsl:template>
</xsl:stylesheet>
KenTan85
I still can't get it work. Is Printwriter still able to be use in jsp to display xml with xsl???
rrz
Log in or sign up to see answer
Become an EE member today7-DAY FREE TRIAL
Members can start a 7-Day Free trial then enjoy unlimited access to the platform
Sign up - Free for 7 days
or
See how we're fighting big data
Not exactly the question you had in mind?
Sign up for an EE membership and get your own personalized solution. With an EE membership, you can ask unlimited troubleshooting, research, or opinion questions.
ask a question
fblack61
