eb110k
How do I load linkaged sound other than frame 1?
I have a pre-loader on frame 1 and configured all linkaged object as "Not export in first frame".
Also I configured "Export frame for class" to frame 10 which labeld "main".
As of result, pre-loader sucessfully starts loading from 0% and bandwidth profiler indicates that the movie has only 1.6KB in first frame.
However, I cannot call linkaged sound object if I configured the objects as "Not export in first frame", but if I configured as "Export in first frame". Thing is that if I configured as "Export in first frame", then pre-loader movie will wait until the objects loaded.
How do I solve this problem?
Please someone advise.
Thank you.
Thank you.
