troubleshooting Question
Need help with writing a Shell script (using awk/sort/sed) to sort "ps -ef" output
Avatar of sunhux
sunhux asked on
Unix OSLinux
23 Comments1 Solution1029 ViewsLast Modified:
Tintin, JustUnix or anyone else,
I would like some help with writing a Shell script to do some sorting/reformatting
of "ps -ef" output for HP-UX & Solaris & Redhat platform :
Eg: example "ps -ef" output :
     UID   PID  PPID  C    STIME TTY      TIME CMD
    root     0     0     0   Apr 21  ?          0:01 sched
    sde 21302  1    0 06:16:04 ?           0:00 /appl/cgs/sdeexe92
    sde 21313  1    0 06:16:12 ?           0:01 /appl/cgs/sdeexe92
Would like the output to be sorted by CMD column in descending
order (as primary key) & then sorted by TIME column in descending
order (as secondary key).
So the output would become :
     /appl/cgs/sdeexe92   0:00  sde 21302   1    0   06:16:04 ?
     /appl/cgs/sdeexe92   0:01  sde 21313   1    0   06:16:12 ?
     sched                         0:01 root     0       0     0   Apr 21  ?
Unlock 1 Answer and 23 Comments.
Learn from the best
Try for 7 days
-Mike Kapnisakis, Warner Bros
