troubleshooting Question
why won't my cisco power injector won't work with my access point?
Avatar of blackjack2003
blackjack2003 asked on
Wireless HardwareNetworking Hardware-Other
3 Comments1 Solution624 ViewsLast Modified:
I'm trying to use a AIR-PWRINJ3 power injector with my cisco aironet 1250 access point, and I have set in the system power settings "pre-standard compatibility" with "installed on port with MAC address" unchecked, as stated in the quick start guide for the access point (for connection to a non-cisco switch), but it will not work.  The access point works with the power supply directly connected, and I have connected the power injector as illustrated in the power injector manual.  Any help would be greatly appreciated.
harbor235
Unlock 1 Answer and 3 Comments.
Learn from the best
Try for 7 days
-Mike Kapnisakis, Warner Bros
