SienaIT
Help with wifi connection to Dell wireless 1395 WLAN mini card.
I have four new Dell Laptops, two are Latitude D830's and two are Precision M6300's that all have this Dell wireless 1395 WLAN mini card. In the office we have wifi setup that all the rest of the laptops can connect to. The new computers with the Dell wireless 1395 WLAN mini card can see the wifi network but they will not connect to it. I have phoned Dell support and the technician remoted in an was unable to figure out the reason why the computers will not connect. Any suggestions to this problem? Thanks
Does your WiFi have security enabled and are the laptops configured to access the wireless?
I am not sure on the Wifi configuration portion of the question. I believe that the Dell Technician checked all that last week when he remoted into the computer. He was checking at the wifi connections. He was able to get this same computer to connect to an secured wireless connection but he couldn't connect to the wifi connection. I will check the security on the wifi and reply on that issue.
The Dell wireless cards will save your configuration even if it is wrong. Make sure you delete the profile that is listed in your Dell Wireless configuration.
What I meant was is how is your Wireless router configured, does it have security enabled and are the laptops already configured, if they are can you try to re-type the access key.
Thanks for the help. The Dell cards are very frustrating and when they can't seem to fix the problem it makes it worse. Thanks again
