Help with conversion of switch control to array...
For a class I am in, I am trying to set up an application that outputs the phonetic alphabet equivalent of a user input letter. It needs to use an array of strings and index the array by letter positions of the alphabet, but I can only get this to work as a switch structure (see attached).
This is an assignment, not a test. Actually, it's an assignment that begs student and teacher collaboration, but high turnaround for communication in this particular online course makes collaboration more frustrating than helpful. Figured I might as well call the experts.
The book usually gives similar coding examples, and until now I have been able to decipher and bend the code to my needs; this is how I learn. However, as far as I can tell the book gives not such coding examples for this, at least none I have been able to figure out.
Any kickstart would be most appreciated. Thanks.
#include <iostream> // Standard I/O
using namespace std;
int main()
    // Solicit input
    char LETTER;
    cout << "Enter the CAPITALIZED letter for which you require the ICAO equivalent:" << endl;
    cin >> LETTER;
// Begin switch control
        switch (LETTER)
        case 'A' : cout << "A = Alpha" << endl;
                   break;
        case 'B' : cout << "B = Bravo" << endl;
                   break;
        case 'C' : cout << "C = Charlie" << endl;
                   break;
        case 'D' : cout << "D = Delta" << endl;
                   break;
        case 'E' : cout << "E = Echo" << endl;
                   break;
        case 'F' : cout << "F = Foxtrot" << endl;
                   break;
        case 'G' : cout << "G = Golf" << endl;
                   break;
        case 'H' : cout << "H = Hotel" << endl;
                   break;
        case 'I' : cout << "I = India" << endl;
                   break;
        case 'J' : cout << "J = Juliet" << endl;
                   break;
        case 'K' : cout << "K = Kilo" << endl;
                   break;
        case 'L' : cout << "L = Lima" << endl;
                   break;
        case 'M' : cout << "M = Mike" << endl;
                   break;
        case 'N' : cout << "N = November" << endl;
                   break;
        case 'O' : cout << "O = Oscar" << endl;
                   break;
        case 'P' : cout << "P = Papa" << endl;
                   break;
        case 'Q' : cout << "Q = Quebec" << endl;
                   break;
        case 'R' : cout << "R = Romeo" << endl;
                   break;
        case 'S' : cout << "S = Sierra" << endl;
                   break;
        case 'T' : cout << "T = Tango" << endl;
                   break;
        case 'U' : cout << "U = Uniform" << endl;
                   break;
        case 'V' : cout << "V = Victor" << endl;
                   break;
        case 'W' : cout << "W = Whiskey" << endl;
                   break;
        case 'X' : cout << "X = X-ray" << endl;
                   break;
        case 'Y' : cout << "Y = Yankee" << endl;
                   break;
        case 'Z' : cout << "Z = Zulu" << endl;
                   break;
  return 0;
carnesc
carnesc
  • 2
2 Solutions
jkrCommented:
You can do that quite easily using the letter as an index into the array. Since array indices usually start a '0', you need to 'normalize' the letter entered by the user by subtracting the numeric value of 'A' (ASCII 6x), e.g.
    char* phonetic[] = {"A = Alpha","B = Bravo","C = Charlie" /*...*/};
    // Solicit input
    char LETTER;
    cin >> LETTER;
    cout << phonetic[LETTER - 'A'];
imladrisCommented:
One way to approach this would be to use the letters numeric value as an index into an array.
That is, an ASCII 'A' is represented by decimal 65, B by 66 etc. So if you use the letters numeric equivalent, subtract 65, and use that as an index into an array of strings, you can easily get the equivalent. Something like:
String phonearray: {  "Alpha", "Bravo", "Charlie" etc. }
cin >> LETTER;
cout<< phonearray[LETTER-65];
carnescAuthor Commented:
Well, that about does it, doesn't it! :)
You both honestly would not believe the dark places into which I was taking this simple program. It is truly a testament to how tired I am right now; my mind has shut down. I could scarf a barrel of whole espresso beans and sleep like a baby. Thank you both.
Thank you both for the help.
The following code is what I handed in for the assignment. It's a little longer, but had fun with it. I created the phonetic array of strings but also a simple string of all characters in the alphabet. The input character is used in my example as a substring search; the match position is stored in another variable; and that integer variable becomes the array instance to print out.
#include <iostream>
// Declare variables and array that holds phonetic alphabet
char letter;
int matchPOS;
char* icao[] = {"A is spoken \"Alpha\"","B is spoken \"Bravo\"","C is spoken \"Charlie\"","D is spoken \"Delta\"", "E is spoken \"Echo\"","F is spoken \"Foxtrot\"","G is spoken \"Golf\"","H is spoken \"Hotel\"", "I is spoken \"India\"","J is spoken \"Juliet\"","K is spoken \"Kilo\"","L is spoken \"Lima\"","M is spoken \"Mike\"","N is spoken \"November\"", "O is spoken \"Oscar\"","P is spoken \"Papa\"","Q is spoken \"Quebec\"","R is spoken \"Romeo\"","S is spoken \"Sierra\"","T is spoken \"Tango\"","U is spoken \"Uniform\"", "V is spoken \"Victor\"" ,"W is spoken \"Whiskey\"","X is spoken \"X-Ray\"","Y is spoken \"Yankee\"","Z is spoken \"Zulu\""};
int main()
      // Solicit input
      cout << endl << "Enter the !!!CAPITALIZED!!! letter for which" << endl <<
                      "you want to know the ICAO phonetic: ";
      cin >> letter; // Store user input
      string searchSTRING; // Declare the Alphabet search string
      searchSTRING = "ABCDEFGHIJKLMNOPQRSTUVWXYZ"; // Populate it
      matchPOS = searchSTRING.find(letter); // Store the matched position
      // Use the matched position to pull from array
      cout << endl << icao[matchPOS] << ". Give it a try!" << endl;
  return 0;
Join & Write a Comment
What Kind of Coding Program is Right for You?
There are many ways to learn to code these days. From coding bootcamps like Flatiron School to online courses to totally free beginner resources. The best way to learn to code depends on many factors, but the most important one is you. See what course is best for you.
  • 2
