amendala
Why do some of my Virtual Machines lose their network connection when they are power cycled?
Greetings -
I have a VMware ESX Server (3.0.2) single host environment and am having some issues with my VM network connectivity. I have a few real (as in, not Virtual) NIC bonded networks set up and for some strange reason, when I power cycle some of my VMs, they lose their network connectivity.
This is indicated in VirtualCenter by showing an IP address of 0.0.0.0. If I go into the configuration for the VM, it shows the "Connected" box for the NIC as unchecked. The fix for this is to check the "Connected" box, switch the network the VM is on to another one temporarily, apply the configuration, and then switch it back to its proper network. The connection to the VM then returns. I have seen this behavior since installing 3.0.2 and never saw this in 2.5.4.
Any idea what's happening here?
Have you upgraded the virtual hw of these VMs after upgrading to 3.0.2?
With respect to being up to date for patches, yes, my installation is up to date on publicly released patches. VMware support indicates that the patches I was sent are "experimental hotfixes" designed to be applied only when experiencing this issue and they are therefore not public. How reassuring. :)
Is your ESX server up to date with patches? Is VMware Tools updated and stated OK in VirtualCenter?
How many physical NICs do you have on your server?
You state that these are NIC bonded? All NICs and does that include the Service Console? And which switches do you use in your physical network?
In the folder where the VM reside on - VMware creates some log files for each VM. Take alook on those to see if you can get any other indications on this error.
