alimohammed72
LAN-to-LAN between PIX-515 and PIX-5252 --Urgent Help Required
Hi
I have setup LAN-LAN tunne lbetween PIX-525 and PIX-515.The host 219..47.190.93/32 is behind PIX-525 and 912.168.243.0/24 is behind PIX-515.I cannot see the tunnel coming up .Also,I do" sh cry isakmp sa" nothing shows up.
The configurations are attached.
Thanks in Advance
23508793-ee-PIX-525.txt
Thanks in Advance
You need an isakmp policy on each side that matches the transform-set
Example:
crypto isakmp policy 15
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
