BryceRichert
need aggressive roaming capable usb wireless adapter suggestions and be able to set minimum wireless speed manually
I need aggressive roaming capable usb wireless adapter suggestions and be able to set minimum wireless speed manually. I have three ap's with same SSID. I want the cards to jump if the speed goes below 20 megs.
Could anyone suggest some products?
Then I would want no connection at all. We have an applicatin that needs a minimum mount of bandwidth to work. Is there a way to have some sort of smart adapter that I can specify the minimum bandwidth needed? It's better to not have a connection than a terribly slow one. AT that point I would just add more AP's to fill the voids, but we can't have the slow connecton.
Thank for any info on this.
20Mbps is a lot of bandwidth, even deducting overhead.
A full T1 line is only 1.5Mbps.
I'm not aware of any adapters you can specify a minimum on, but I'll see what I can find.
This is an internal LAN
are there AP's that provide 40-45Mbps per client?
Or to have the client get that full 40-45Mbps do I need a seperate AP per client? That would sound silly. There are AP's at other places serving 20-30 people.
Do you want it to keep hopping from one to another in that case?
