maderosia
OWA's /exchange virtual directory will not work for 2007 mailbox users
I have installed Exchange 2007 SP1 as a CAS role on Server 2008. I have migrated my mailbox over to our 2007 mesaging envrionment. When I access OWA I am able to log in using the /OWA virtual directory but I cannot log in using the /exchange virtual directory. When I attempt to log in using the forms based authentication, it just displays a line "The user name or password that you entered is not valid. Try entering it again." Users with a 2003 mailbox are able to log in with no problems using the /exchange. I do not know where the problem could be here. I have uninstalled and reinstalled IIS and exchange as described in this article. http://support.microsoft.com/kb/320202. I am running out fo things to look at. I am recieving this error directly on the CAS servers via https://localhost/owa and https://localhost/exchange. The Windows firewall is turned off.
jkarnes12, that is not correct. /exchange is for 2000 and 2003 mailboxes and will redirect 2007 mailboxes to /owa. It is the practice to use the /exchange directory during a migration as it will control the virtual directory needed. And when all users are on 2007, to then start using the /owa directory for all OWA. It would be inpossible to publish different webs for users dependant on where their mailbox is without the /exchange redirecting automatically. Here is a good reference that will explain this: http://technet.microsoft.com/en-us/library/bb885041.aspx
The /exchnage directory is for Legacy Exchange mailboxes (2003)
