Need some help with System.Drawing.PointF or System.Drawing...
Hi... Me again...
I have HTTPHandler method that draws a watermark ontop of my product images. Slightly modified from this article to fit my HTTPHandler ( http://blog.donnfelker.com/2007/09/18/WatermarkingImagesInASPNETWithAnHttpHandler.aspx )
I want to make the watermark display ontop the image in a angle, from top left to bottom right... Also want it to extend the length of the image and never overlap?
Anyone know how i can do that?
Nugs
protected static System.Drawing.Image WatermarkImage(System.Drawing.Image image, string watermark)
        Graphics graphic;
        if (image.PixelFormat != PixelFormat.Indexed && image.PixelFormat != PixelFormat.Format8bppIndexed && image.PixelFormat != PixelFormat.Format4bppIndexed && image.PixelFormat != PixelFormat.Format1bppIndexed)
            graphic = Graphics.FromImage(image);
        else
            Bitmap indexedImage = new Bitmap(image);
            graphic = Graphics.FromImage(indexedImage);
            graphic.DrawImage(image, 0, 0, image.Width, image.Height);
            image = indexedImage;
        graphic.SmoothingMode = SmoothingMode.AntiAlias & SmoothingMode.HighQuality;
        Font myFont = new Font("Arial", 10, FontStyle.Bold);
        SolidBrush brush = new SolidBrush(Color.FromArgb(80, Color.White));
        SizeF textSize = graphic.MeasureString(watermark, myFont);
        //WRITE THE TEXT ACROSS THE IMAGE.
        //for (int y = 0; y < image.Height; y++)
        //    for (int x = 0; x < image.Width; x++)
        PointF pointF = new PointF(0, image.Height / 2);
        graphic.DrawString(watermark, myFont, brush, pointF);
        //        x += Convert.ToInt32(textSize.Width);
        //    y += Convert.ToInt32(textSize.Height);
        return image;
Nugs
Nugs
NugsAuthor Commented:
Ok i managed to get the 45 degree angle. But how to i scale the text to fit the size of the image?
Nugs
        Graphics graphic;
        else
        Rectangle rectan = new Rectangle(0, 0, image.Width, image.Height);
        graphic.FillRectangle(Brushes.Transparent, rectan);
        graphic.DrawString(watermark, myFont, brush, 0, 0);
        graphic.RotateTransform(45);
        return image;
Bob LearnedCommented:
I would think, on the surface, that you need to find a ScaleTransform ratio that gives you the "stretch" that you need.
Join & Write a Comment
What Kind of Coding Program is Right for You?
There are many ways to learn to code these days. From coding bootcamps like Flatiron School to online courses to totally free beginner resources. The best way to learn to code depends on many factors, but the most important one is you. See what course is best for you.
