troubleshooting Question
How to speed up bit level operations using parallelism ?
Avatar of HukkaHua
HukkaHua asked on
ProgrammingCAlgorithms
4 Comments2 Solutions347 ViewsLast Modified:
Hi FOlks,
               This is straight from the Programming Pearls Book :
Show how to speed up the initialization and reporting operations on
bit vectors by using parallelism to operate on many bits at a time.
Is it most efficient to operate on a char,short, int, long or some other
unit ?
Any ideas? Suggestions, thoughts are welcome.
-H
Unlock 2 Answers and 4 Comments.
Learn from the best
Try for 7 days
-Mike Kapnisakis, Warner Bros
