troubleshooting Question
Will 533MHz cpu and memory work in Motherboard w/ 800MHz FSB
Avatar of dzacharczyk
dzacharczyk asked on
Components
2 Comments1 Solution570 ViewsLast Modified:
Will 533MHz cpu and PC2-4200 memory work on a motherboad w/ 800MHz FSB. I was under the impression that you can combine use slower cpu and memory as long as they match with motherboard that is rated for a higher bus speed. Is this correct?
Here is a link to the motherboard I have:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3135545&CatId=1533
Thank you in advance for your help.
Unlock 1 Answer and 2 Comments.
Learn from the best
Try for 7 days
-Mike Kapnisakis, Warner Bros
