ASP.NET project reference and assemblies problem.
I recently recompiled part of the CyberSource API because I was getting a strange error. After deleting the old reference and adding a reference to the recompiled DLL file, I got this error and I can't seem to get rid of it:
" Could not load file or assembly 'SoapClient, Version=, Culture=neutral, PublicKeyToken=7091342136fdb0df' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)"
I've deleted all references to this DLL in all referenced projects and readded them, pointing to the new, recompiled DLL. I've even deleted ALL occurrences of the .dll on all my hard drives, and recompiled a new version.
My reference is in a web service running under 2.0. The .DLL is compiled under .NET 1.1. My colleagues have had no problems doing the exact same thing on their systems.
I am totally out of ideas. Any help would be greatly apreciated.
Best Regards,
Alex Percsi.
gdupadhyayConnect With a Mentor Commented:
There is a utility called gacutil.exe. Please use this to install or unstall the assembly from GAC.
Please read this article
I hope it will help u.
Let me know if you have some question.
Did you uninstall and install the same assembly from GAC?
alexpercsiAuthor Commented:
The assembly was not in the GAC, best as I can tell. Could you give me a walk through on how to do this?
