need help with volume controls on certain features
sometimes I set my volume to high when I go to sleep but am disturbed by pages or calls at night when all I really need the volume that high for is my alarm. Is there anyway to change the settings for multipule volume control for certain features.
Jobox
Jobox
jahboiteCommented:
In the manual, available at
http://www.blackberry.com/knowledgecenterpublic/livelink.exe/fetch/2000/8067/645045/8533/1360749/BlackBerry_8830_World_Edition_Smartphone_-_User_Guide_(version_4.2.2)?nodeid=1360681&vernum=0
for example, it says
"In the BlackBerry® device alarm, you can set the alarm to sound at the same time everyday or only on weekdays. You can also set a snooze
time for the alarm and adjust the alarm volume."
"Turn on the alarm
1. In the alarm, change the Daily Alarm field to On or Weekdays Only.
2. Change the alarm options.
A bell indicator appears beside the date in the device status section of the screen."
So it sounds like you can turn the volume down and set the volume high for the alarm.
Does that work for you?
JoboxAuthor Commented:
Concerto Cloud for Software Providers & ISVs
Can Concerto Cloud Services help you focus on evolving your application offerings, while delivering the best cloud experience to your customers? From DevOps to revenue models and customer support, the answer is yes!
Learn how Concerto can help you.
