Manoj Prasad
weird connectivity issue between serial0 connection and a switch
I have a Cisco 1720 router with a T1 CSU/DSU WIC in it. The building has a T3 that it splits up and gives to the companies in the building. They have given us an IP address that I used for the serial interface. After I configured the router (config to follow...), the WIC was in alarm. Couldn't figure out why. Eventually, I transformed an RJ-45 Ethernet cable into an RJ-48C cable (spliced wires 1,4 and 2,5) and the amber alarm light went off. Serial0 interface now shows as UP. However, the lights on the Router are all green, but there is no light on the switch. It's like the switch doesn't see it. I've switched cables, ports, etc. to no avail. The local network behind the router cannot access anything outside the router. Any ideas what is wrong? Here's the router config:
version 12.1
no service single-slot-reload-enable
service timestamps debug datetime localtime
service timestamps log datetime localtime
service password-encryption
hostname router_axx
no logging buffered
no logging buffered
logging rate-limit console 10 except errors
enable secret 5 $1$DNwM$rmHCiTTpun2RRBHm4k K6f.
memory-size iomem 25
clock timezone MST -7
clock summer-time MDT recurring
ip subnet-zero
no ip finger
ip name-server 12.127.xxx.71
ip dhcp excluded-address 10.20.20.1
ip dhcp excluded-address 10.20.20.251
ip dhcp excluded-address 10.20.20.252
ip dhcp excluded-address 10.20.20.253
ip dhcp pool ais
network 10.20.20.0 255.255.255.0
default-router 10.20.20.1
domain-name ais_regus
dns-server 12.127.xxx.71
interface FastEthernet0
ip address 10.20.20.1 255.255.255.0
ip access-group 100 in
ip access-group 100 out
ip nat inside
speed auto
full-duplex
no cdp enable
interface Serial0
ip address 12.41.xxx.30 255.255.255.224
ip nat outside
no cdp enable
ip nat pool nat-pool 12.41.xxx.30 12.41.xxx.30 netmask 255.255.255.240
ip nat inside source list 1 pool nat-pool overload
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0
no ip http server
access-list 1 permit 10.20.20.0 0.0.0.255
access-list 100 permit tcp any any
access-list 100 permit udp any any
access-list 100 permit ip any any
access-list 100 permit icmp any any
no cdp run
line con 0
transport input none
line aux 0
line vty 0 4
password 7 14300705020D397B2A
login
no scheduler allocate
end
version 12.1
hostname router_axx
no logging buffered
no logging buffered
ip subnet-zero
no ip finger
ip dhcp pool ais
ip nat inside
speed auto
full-duplex
no cdp enable
interface Serial0
ip nat outside
no cdp enable
ip classless
no ip http server
no cdp run
line con 0
line aux 0
line vty 0 4
login
end
What, exactly, are you connecting the T1 interface to? It cannot plug into an Ethernet switch!
Okay, so how can this be done then? Once again, I've got a single public IP that I have been assigned, and am using PAT on the router. My network of 5 or so people are behind the router. What do I connect the router's serial interface to?
BTW... you connect the serial interface to nothing. :)
Thanks Pugglewuggle. That makes sense. I knew it was something easy I was just missing! I'll go buy a new WIC for it. Thanks again!!
