How to connect cisco switches together with fibre optic LC-LC cable
Please i need to connect 6(six) 2960 cisco switches together with fibre optic LC-LC  cable, i have connected two just by plugging to the intergtaed GBIC on the switch, unfortunately i cannot ping across each other.
I will be grateful if someone can just advice me how i can connect the six together .
lawre1108
lawre1108
from_expCommented:
hi!
if the ports are not coming up, try swapping fiber strands.
if ports are up, please check configuration settings.
please also provide show int <interface> and show running-config int <interface> from both switches
Gunter17Commented:
Make sure you have the 'switchport mode trunk' set on the ports; int erface config should look like:
interface GigabitEthernet0/1
 description Link to SW#
interface GigabitEthernet0/2
You are planning on doing something similiar to this?
SW1
P1=SW2-P1
SW2
P1=SW1-P1 P2=SW3-P1
SW3
P1=SW2-P2 P2=SW4-P1
SW4
P1=SW3-P1 P2=SW5-P1
SW5
P1=SW4-P1 P2=SW6-P1
SW6
P1=SW5-P1
lawre1108Author Commented:
Thanks Gunter17, i just get them working the way you show it i can ping from each switch now.
There is no need to swap the cable, because LC-LC have the same type of end.
Thanks for your help.
Join & Write a Comment
Worried about phishing attacks?
90% of attacks start with a phish. It’s critical that IT admins and MSSPs have the right security in place to protect their end users from these phishing attacks. Check out our latest feature brief for tips and tricks to keep your employees off a hackers line!
