having a problem with <div> tags and z-index with over laying text.
hello,
i have created a banner with <div> tags and z-index with overlying text layer.  it shows up correct in firefox but in ie the text breaks lines after each word. does anyone see an issue with my code?
thanks
<!--BACKGROUND COLOR-->
<div style="width:369px; height:150px; z-index:1; position:absolute;"><a href="/catalog/theme.jsp?themeId=381&"><img src="10-15-08_christmas_store_feature_2.jpg" alt=" Shop 2008 Collectibles" width="369" height="150" border="0"></a></div>
<!--COPY-->
<div style="width:199px; height:95px; padding-left:20px; padding-right:150px; padding-top:55px; z-index:2; font:Arial, Helvetica, sans-serif; font-size:14px; color:#FFFFFF; position:absolute;">
shop 2008 collectible items
</div>
<!--COPY-->
nooch44
nooch44
scrathcyboyCommented:
try using in CSS -- display:inline;    or display:inline-block;   to style the text giving problems.
MattKenefickCommented:
in IE.. padding subtracts from the total width of an object as opposed to adding to it.
So when you have and object that is about 200px wide.. and you have 20px padding on left, and 150px padding on right... That only leaves 30px of space for words.. Which is why your words are breaking.
nooch44Author Commented:
took the padding on the righ away and it did the trick...thanks
Join & Write a Comment
What Kind of Coding Program is Right for You?
There are many ways to learn to code these days. From coding bootcamps like Flatiron School to online courses to totally free beginner resources. The best way to learn to code depends on many factors, but the most important one is you. See what course is best for you.
