Solved
Why is my OpenVPN connection so much slower than my internet connection speed?
Posted on 2008-10-17
6
Last Modified: 2012-06-21
I have an OpenVPN tunnel set up between the two sites using TCP and port 51194 with encryption. The VPN server and client are also the router for each site and are running an ubuntu package from ebox-platform.com
I am experiencing slow speeds pulling files from a Windows 2003 Server in site A to a workstation in site B. I can achieve much faster speeds sending files from site B to site A.
I have compared the speeds of transfering files from site A to site B using FTP and VPN.
VPN - 30 KB/s       FTP - 200 KB/s
Transferring a file from site B to the server in site A I get speeds upwards of 120 KB/s.
I understand there is some overhead using VPN, but I am only getting about 20% of my maximum site 1 upload speed. I can greater bandwidth if needed. However is there anything to help me get better performance from the OpenVPN?
Question by:mattattat
  • 2
4 Comments
LVL 8
Accepted Solution
by:
sstone55423 earned 672 total points
You need hardware VPN to get better speeds.  Something like a Sonic Wall Firewallwould work great.
Also, is your ISP connection (used for VPN) a DSL or Cable modem?  They have different speeds up versus down.
LVL 63
Assisted Solution
by:SysExpert
SysExpert earned 336 total points
I would try with a router based VPN in hardware, since you may be taxing your servers ( check resource usage, CPU, RAM, IO etc )
have you a speed comparison done without the VPN tunnel. You do not always get the spped you think you should be getting.
I hope this helps !
Author Comment
by:mattattat
I checked the resources on the routers while using the VPN. They barely registered any usage.
I did switch the protocol to UDP and am now getting about 75%-80% of my upload speed. Is this about as good as I should expect?
LVL 8
Assisted Solution
by:sstone55423
The general rule of thumb with TCP/IP is 70% efficiency, so it sounds like you are doing pretty good.
But, the question is why is TCP so much slower outside of the VPN than within the VPN?
The reason I asked about the cable modem or DSL is that there are usually faster in one direction than the other, and you describe the issue as faster in one direction than the other.
Some of you may have heard that SonicWALL has finally released an app for iOS devices giving us long awaited connectivity for our iPhone's, iPod's, and iPad's. This guide is just a quick rundown on how to get up and running quickly using the app. …
Let’s list some of the technologies that enable smooth teleworking.
After creating this article (http://www.experts-exchange.com/articles/23699/Setup-Mikrotik-routers-with-OSPF.html), I decided to make a video (no audio) to show you how to configure the routers and run some trace routes and pings between the 7 sites…
Windows 10 is mostly good. However the one thing that annoys me is how many clicks you have to do to dial a VPN connection. You have to go to settings from the start menu, (2 clicks), Network and Internet (1 click), Click VPN (another click) then fi…
Suggested Courses
580 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
