My regex is very inefficient and slow...help with improving speed
I'm using two regex's.  I was trying to allow for any wildcard in the domain portion of an email address to be allowed through the first one, and caught by the second one.  My app is getting hung with the first one if the domain is more than like 8 chars.
emailReg = /^[a-z0-9_-]+((.*?[a-z0-9_-])*)@[a-z0-9]+(.*?[a-z0-9])*\.([a-z]{2,}|[0-9]+)$/i
Also,
should I be using .exec or .test?  What's faster?
does the /i slow things up?  Is it because of the .*? in the 2nd substring after the @ because I'm basically allowing unlimited strings?
This is my more thorough check
/^[a-z0-9_-]+(([.]?[a-z0-9_-])*)@([a-z0-9])+([\.\-]?[a-z0-9]*)*\.([a-z]{2,}|[0-9]+)$/i
which, if it passes form on the first one, goes through this one.  not my idea but the business wants 2 error messages.
Any help with efficiency and improving speed on both of these would be most appreciated.  Thanks
Bishork
Bishork
  • 11
  • 9
ozoCommented:
(.*?[a-z0-9])*
can match in multiple ways, and it may take exponentially long to fins all possible ways it might match
([^a-z0-9]*[a-z0-9])*
should match only one way so it should be more efficient
ozoCommented:
in fact
((.*?[a-z0-9_-])*)
is equivalent to just
(.*([a-z0-9_-]))
but without all the backtracking
BishorkAuthor Commented:
(.*([a-z0-9_-]))
wont let you have a string of any char like .*? would.  .*? allows ######F but .? requires #F#F#F#F#F
Concerto Cloud for Software Providers & ISVs
Can Concerto Cloud Services help you focus on evolving your application offerings, while delivering the best cloud experience to your customers? From DevOps to revenue models and customer support, the answer is yes!
Learn how Concerto can help you.
in fact
((.*?[a-z0-9_-])*)
(.*([a-z0-9_-]))
i thought ? meant lookahead, and without it it wouldnt look ahead.
oh wait i see what you did thar, nm lemme test that out
do you prefer .test or .exec  and do you prefer /i?
last q - why'd you use a ^ in
if i put that part in the domain portion, i dont need the ^ since it isnt the start of the string right
ozoCommented:
if you don't have /i
you'd probably want to change [a-z] to [a-zA-Z]
either way should make little difference in efficiency
Last Q, then ill give you the pts right now -
which is superior, the way using what you gave me above:
/^[a-z0-9_-]+(.*([a-z0-9_-]))@[a-z0-9]+([^a-z0-9]*[a-z0-9])*\.([a-z]{2,}|[0-9]+)/i
then if you pass through that you go to
/^[a-z0-9_-]+(([.]?[a-z0-9_-])*)@([a-z0-9])+([\.\-]?[a-z0-9]*)\.([a-z]{2,}|[0-9]+)$/i
or this simpler way:
for the first check, then if test is true, you get an error
if that is false, you go through
/^([a-z0-9._%+-])+@[a-z0-9.-]+\.[a-z0-9]{2,4}$/i
ozoCommented:
in a character class
[^...] matches any character not in [...]
j@cnn.com wont work with (.*([a-z0-9_-])) because its requiring that as a second char.
will it make it do all the backtracing if i make it (.*([a-z0-9_-]))*
ozoCommented:
Adding that * can potentially cause it to spend a lot of time backtracking, and doesn't change what is matched (it just lets there be a lot if different ways of matching the same thing)
Why do you think you need it?
(.*([a-z0-9_-]))* = look for 0 or many of anything thats followed by what's in []
(.*([a-z0-9_-])) = look for one or more (or one any only one).  right?  although I don't have a {1} or a + I thought leaving any delimiter off means it defaults to one of those.  When I run it in my test it's requiring i have two chars before the @
Are ([^a-z0-9]*[a-z0-9])* and (.*([a-z0-9])) equally efficient?
ozoCommented:
not exactly equal, but neither will blow up exponentially.
They differ in what they will match in that the first can match an empty string while the second will not
They also differ in what the parentheses will capture
ozoCommented:
leaving any delimiter off means it defaults to {1}
(.*([a-z0-9_-])) requires at least one character,
(.*([a-z0-9_-]))* requires at least 0 characters
(.*([a-z0-9_-]))? also requires at least 0 characters
so last q - would you prefer i just do the first check as
[.@][.@]+ test for that, if they have @@ @. .@ .. it then youll get error.  if you pass that, then just have
/^([a-z0-9._-])+@[a-z0-9.-]+\.[a-z0-9]{2,4}$/i
make it alot simpler?
ozoCommented:
Exactly what strings do you want to match, and what strings do you want to not match?
the first one i want to catch bad form and the second i want to catch invalid symbols in the address.
like - j...@joe.com should be caught by the first one, j#ck@joe.com should pass through the first one and be caught by the second.  see what i was trying to do by allowing anything to pass through the first one after the first letter?
ozoCommented:
Although I don't know whether j... or j#ck happen to exist on joe.com, those happen to be perfectly valid email addresses
thanks
We value your feedback.
  • 11
  • 9
