How do DTech4003 Multicard reader audio cable pins fit into normal motherboard front panel audio connetor
Can I locate a diagram that shows how to configure the audio cable strap of the DTech DT 4003 multi card reader with the normal 10 socket  front  audio connector on a motherboard? It's strap is as follows
Flat white (various red codings) audio cable strap ( including (mic-r&l;front r&l; Rearr&l; bass;center;ground))  and these do not  match normal mobo diagrams of front panel audio connector sockets.
The panel front includes mic in(pink); rear out;(green); front out(blue; Cen-bass (orange) 3.5mm sockets
kinerang
kinerang
  • 3
  • 2
nobusCommented:
it should be listed in your DTech4003 Multicard  reader   manual
kinerangAuthor Commented:
Unfortunately no such manual was with the device. I've just checked the box again.
Thanks for the link I have used it to email the DTECH "overseas email" section and explained the need foe a diagram. If I get nowhere in the next few days I may need to return to this forum to get some other help. However in the mean time thanks heaps!!
nobusCommented:
>>  The panel front includes mic in(pink); rear out;(green); front out(blue; Cen-bass (orange) 3.5mm sockets   <<  after re-reading this seems the front panel itself - but you should connect it to the motherboard audio connector  imho
what mobo do you have ?
Concerto Cloud for Software Providers & ISVs
Can Concerto Cloud Services help you focus on evolving your application offerings, while delivering the best cloud experience to your customers? From DevOps to revenue models and customer support, the answer is yes!
Learn how Concerto can help you.
  • 3
  • 2
