Solved
Wireless to wireless pinging problem.
Posted on 2008-10-21
Last Modified: 2013-11-09
Just installed 29 Cisco 1242 devices.  From hardlines I can ping any device on any AP.  From a wireless device, I can ping any device not on the same AP.  What stops the pinging on the same AP?
Question by:gregsharp1
  • 2
4 Comments
LVL 3
Expert Comment
by:sullivanr6
an ICMP relay. the wireless LAN needs to route traffic to a gateway that can reach all the AP's.
can you go from one AP to another without dropping pings?
Author Comment
by:gregsharp1
Yes, can roam from AP to AP without dropping.  All devices are on the same SSID.  Most of the wireless devices are stationary computers and Intermec printers.  APs are connected to the same Catalyst 4000 switch.
LVL 8
Accepted Solution
by:
MrJemson earned 2000 total points
Sounds like Wireless Isolation is enabled...
On the 1242 Web Interface:
Go to Network Interfaces, select Radio0-802.11G or A then settings, and look for (PSPF) Public Secure Packet Forwarding, Choose Disable.
Author Closing Comment
by:gregsharp1
Thanks.
SMB Security Just Got a Layer Stronger
WatchGuard acquires Percipient Networks to extend protection to the DNS layer, further increasing the value of Total Security Suite.  Learn more about what this means for you and how you can improve your security with WatchGuard today!
Last Mile Wireless The term last mile wireless is a bit deceptive as it can be much more than a mile. It is also called WiMax and 802.16. It generally refers to relatively short distance point-to-point / point-to-multipoint secure wireless connecti…
This program is used to assist in finding and resolving common problems with wireless connections.
As many of you are aware about Scanpst.exe utility which is owned by Microsoft itself to repair inaccessible or damaged PST files, but the question is do you really think Scanpst.exe is capable to repair all sorts of PST related corruption issues?
Suggested Courses
640 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
