How do I change the recordsource of a subreport within another subreport using VBA. Changing a subreport recordsource is possible of course using VBA but I have not found a way to go another level
I am using an ADP in Access 2000
How do I change the recordsource of a subreport within another subreport using VBA. Changing the
recordsource in a subreport is of course possible eg.
Reports(0)("subreport").Report.RecordSource = strSQL
but I have not found a way to do it for another level deeper. I keep getting the error messsage 'object doesent support this property or method'
HatchIT
HatchIT
  • 2
Vadim RappCommented:
reports!report1.subreport1.report.subreport2.report.recordset
or ...recordsource
Veeam Disaster Recovery in Microsoft Azure
Veeam PN for Microsoft Azure is a FREE solution designed to simplify and automate the setup of a DR site in Microsoft Azure using lightweight software-defined networking. It reduces the complexity of VPN deployments and is designed for businesses of ALL sizes.
  • 2
