Online Test Engine and e-Learning Engine components in ASP.Net
Hello Experts,
Is there any ASP.Net online test engine and/or e-learning engine available which can be used to create an e-learning solution or online evaluation solution. I am looking for some component which can be used to build a solution so that I dont have to re-invent the wheel. Please let me know if there is any commercial (or even free) components available. Also how to get an eval of the same.
FSS
firstwareAsked:
Luis PérezSoftware Architect in .NetCommented:
Mmm... really I've not found any commercial solution for this, at least in ASP.NET. You can try this URL, but I'm not sure that this is what you're looking for. Good luck, anyway!!
http://www.asp.net/Learn/videos/video-04.aspx
.NET Programming
