Solved
Using Class Module to connect VBA to SQL
Posted on 2008-10-29
8
Last Modified: 2013-11-25
An Access 2003 front end connects to a SQL server through a LAN.  The system was developed over four years.  It commenced as a Jet dbase and progressed to connecting to a SQL 2000 dbase over a LAN.  The coding is in VBA and has 80 occurrences in the coding to connect to the SQL server.
The database is migrating to a hosted server.  Some users will have a new web based access to a limited part of the system.  However we need to retain the functionality of the backend office to the system.
It is time to clean up the connection to the database.  It has been suggested that it would be a good opportunity to use a class module.  The new object can just be referenced.
This is a learning curve.  I have included two snippets of code:
1 the class module to initialise, terminate, Execute and create client cursor
2 the current calling procedure
I would appreciate suggestions where the constants should be placed and how to set the object.  What happens when the connection drops out?  How can I check for a connection?
'Constants
DBCONNSTRING = "Provider=SQLOLEDB.1;UID=imexfx;Password=********;Initial Catalog=dyna***********;Data Source=123.123.123.123,1433"
DATAERRORSTR = "Database Not Available"
'---------- Data Class ----------'
Class DataConn
 Private m_objConn
 Private Sub Class_Initialize()
  On Error Resume Next
  If Not isObject(m_objConn) Then
   Set m_objConn = Server.CreateObject("ADODB.Connection")
   m_objConn.Open(DBCONNSTRING)
  End If
  If Err.Number <> 0 Then
   Response.Write(DATAERRORSTR)
   Response.End()
  End If
 End Sub
 Private Sub Class_Terminate()
  If isObject(m_objConn) Then
   m_objConn.Close
   Set m_objConn = Nothing
  End If
 End Sub
 ' Execute Method
 Public Function Execute(strSQL)
  Set Execute = m_objConn.Execute(strSQL)
 End Function
 ' Create Static Recordset Method
 Public Function CreateClientCursorRS(strSQL)
  Set m_objRS = Server.CreateObject("ADODB.Recordset")
   m_objRS.CursorLocation = adUseClient
   m_objRS.Open strSQL, m_objConn,, adLockReadOnly, adCmdText
  Set CreateClientCursorRS = m_objRS
 End Function
End Class
________________________________________________________________
Private Sub Test_Click3()
  ' test connection
   Dim rst As New ADODB.Recordset
   Dim cnn As New ADODB.Connection
   Dim strSQL As String
   Dim msg As String
   On Error GoTo ErrHandle
   strSQL = "tblCountry"
   strSQL = strSQL & " WHERE Cntry = 'AUS'"
   Set rst = New ADODB.Recordset
   Set cnn = New ADODB.Connection
   cnn.CursorLocation = adUseClient
   cnn.Open "Provider=SQLOLEDB.1;Password=*********;Persist Security Info=True;User ID=imexfx;Initial Catalog=dyn*********;Data Source=123.123.123.123"
   rst.Open strSQL, cnn, adOpenStatic, adLockOptimistic, adCmdTable
   If rst.RecordCount = 1 Then
    Debug.Print "Success"
    msg = "success connecting to dynamicwebsites" & vbCrLf & Err.Description
    MsgBox msg, vbExclamation, "Form Main Menu"
   Else
    Debug.Print "Failed"
   End If
Exit_Sub:
    Exit Sub
ErrHandle:
    msg = "Problem Testing connection" & vbCrLf & Err.Description
End Sub
Question by:Nigel Keith-Walker
  • 6
8 Comments
LVL 9
Expert Comment
by:borki
I am a bit confused by your question. Are you saying that your DB is already working fine with SQL Server on a local LAN and all you are doing is moving the DB server to a WAN location?
If this is the case, all you need to change is the timeout value in the connection string.
How are your forms & reports connecting to the DB? I am sure they don't call/use your VBA class module?
Also, have you looked at Access Data Projects?
Let us know
Felix Burkhard
Author Comment
Yes the Access front end works fine with the LAN server.
However I am opening the connection to it in each procedure function, and I am not coding a close connection.  I thought that it was time to make the code more effective. Also I do need to set the cursor to the client side.
LVL 85
Accepted Solution
by:
Scott McDaniel (Microsoft Access MVP - EE MVE ) earned 1600 total points
It would seem to me that all you'd need to do would be to create (a) a global ADODB connection object and (b) a DBConnect function in a Standard Module ... I really don't see the need for a class module in this instance. For example:
public gCON as ADODB.Connection
Function DBConnection() As Boolean
If gCON is Nothing then
  Set gCON = New ADODB.Recordset
Else
  If gCON.State = adStateClosed Then
    gCon.Open "Your connect string"
  End If
End If
'/now test
DBConnect = gCON.State = adStateOpen
End Function
From there just change your 80 code references to use the gCON connection object, and call DBConnect before you run anything ... if DBConnect is False, you could inform the reader, try connecting again, log the failure, etc etc.
This is somewhat crude, and you'd need to test it thoroughly and include error handling also. There are aslo several types of gCON.STate to consider - do a little research on this to figure out the best way to handle these.
We value your feedback.
Author Comment
Thanks LSM
Where does the Global ADODB connection need to be set up? Should the coding be placed in the . Microsoft Office Access Class Objects > Form_Main Menu
There VBA folders are:
. Modules
. Class Modules
Author Comment
Borki
Currently the forms and reports are connecting to the LAN database using code similar to the test_click procedure.
There is insufficient resourcing to rebuild the system as a project.  The system has developed over four years.
Author Comment
I have amended the suggested code and added it to Modules.  The Function DBConnection is now called from the VBA behind one of the forms.  From the immediate window the GCON connection is open in the function, but not available when it returns control to the form VBA.
How can the connection GCON be made available to all forms and reports?
public Const DBCONNSTRING = "connection string to SQL server"
  Set gCON = New ADODB.Connection
  gcon.cursorlocation = aduseclient
  gcon.open
Else
    gCon.Open DBCONNSTRING
  End If
End If
'/now test
End Function
Author Comment
re last posting
Checking the coding there were two declarations of gcon.  Having removed the public declaration in the VBA behind the Access forms and reports has allowed connection.  I will test further.
Author Closing Comment
I posted the coding that I actually used.  I have now replaced 80 occurrrences with a single function.  I have completed the user testingf of the package.  Thanks.
[Webinar] Database Backup and Recovery
Does your company store data on premises, off site, in the cloud, or a combination of these? If you answered “yes”, you need a data backup recovery plan that fits each and every platform. Watch now as as Percona teaches us how to build agile data backup recovery plan.
Explore the ways to Unlock VBA Project Password Excel 2010 & 2013 documents. Go through the article and perform the steps carefully to remove VBA Excel .xls file.
A quick solution showing how to control and open a POS Cash Register Drawer using VBA with MS Access.
Viewers will learn how the fundamental information of how to create a table.
Viewers will learn how to use the SELECT statement in SQL to return specific rows and columns, with various degrees of sorting and limits in place.
Suggested Courses
609 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
