Solved
Problem passing query to MS SQL using DBI module
Posted on 2008-10-31
38
Last Modified: 2012-05-05
I have the attached code using the DBI module doing a query to MS SQL.  When I pass it:
Global Sourcing - IT
it works fine. I get the following:
Global Sourcing - IT's USD group number is 9244800
If I pass it something with astericks in it (which I have no control over):
Applications *** Internal Use Only ***
 I get the following, which replaces the astericks with files that are in the directory where the script is running:
Applications test.pl test2.pl wm_logwatch.pl working_hash_test.pl Internal Use Only test.pl test2.pl wm_logwatch.pl working_hash_test.pl not found.
Is there any way to make this work?
Thanks!
David
#!/perl -w
use DBI;
use DBD::ODBC;
use Carp;
$test = <@ARGV>;
my $DSN = 'driver={SQL Server};Server=SQLSERVER01;database=ahd;uid=reports;pwd=reports;';
my $dbh = DBI->connect("dbi:ODBC:$DSN") or print "$DBI::errstr\n" and croak $!;
my $SQL = "select id, sym from ahd.ahd.zgrplist order by sym";
my $sth = $dbh->prepare($SQL) or print "$DBI::errstr\n" and croak $!;
$sth->execute() or print "$DBI::errstr\n" and croak $!;
while (($id, $group) = $sth->fetchrow_array()) {
    chomp ($id, $group);
    ( index ( $test, $group ) >= 0 ) and print "$group" ."\'s USD group number is: $id\n" and exit 1;
$dbh->disconnect();
Question by:David Aldridge
  • 19
  • 15
  • 4
38 Comments
LVL 1
Author Comment
by:David Aldridge
btw, I've tried quotes, double quotes, and even replacing * with \* and nothing works so far.
LVL 13
Expert Comment
by:kawas
have you tried using a prepared statement? btw, how can you pass anything into your query when you are showing a simple select statement with no WHERE clause?
LVL 1
Author Comment
by:David Aldridge
Because it's not a long list and I am getting the entire contents of id and sym fields and putting them into an array.
I'm not sure what you mean by passing it a prepared statement.  Can you explain?
Thanks!
We value your feedback.
LVL 13
Expert Comment
by:kawas
something like the snippet below.  note foo = ? and $my_foo_value_here
my $SQL = 'select id, sym from ahd.ahd.zgrplist order by sym WHERE foo = ?';
$sth->execute($my_foo_value_here) or print "$DBI::errstr\n" and croak $!;
LVL 13
Accepted Solution
by:
kawas earned 1000 total points
Explanation
" The prepare call prepares a query to be executed by the database. The argument is any SQL at all. On high-end databases, prepare will send the SQL to the database server, which will compile it. If prepare is successful, it returns a statement handle object which represents the statement; otherwise it returns an undefined value and we abort the program. $dbh->errstr will return the reason for failure, which might be ``Syntax error in SQL''. It gets this reason from the actual database, if possible.
The ? in the SQL will be filled in later. Most databases can handle this. For some databases that don't understand the ?, the DBD module will emulate it for you and will pretend that the database understands how to fill values in later, even though it doesn't."
from http://www.perl.com/pub/a/1999/10/DBI.html
LVL 1
Author Comment
by:David Aldridge
I guess I'm just dense.  I can't figure out what's different in that and what I was doing the first time.  Is what I'm doing here not a prepared statement?  But you did raise a good point and instead of dumping everything to an array and searching it, I can do a specific query based on the $test which is passed to the script.  The script now looks like this and works as before, but still breaks if there is an asterick in $test.
#!/perl -w
use DBI;
use DBD::ODBC;
use Carp;
$test = <@ARGV>;
my $SQL = "\'select sym from ahd.ahd.zgrplist order by sym WHERE id = $test\'";
$sth->execute($SQL) or print "$DBI::errstr\n" and croak $!;
($id) = $sth->fetchrow_array();
print "$test" ."\'s USD group number is: $id\n" and exit 1;
$dbh->disconnect();
LVL 1
Author Comment
by:David Aldridge
As a matter of fact, I don't need "order by" either, so that line looks like this:
my $SQL = "\'select sym from ahd.ahd.zgrplist WHERE id = $test\'";
LVL 13
Expert Comment
by:kawas
change:
to
my $SQL = 'select sym from ahd.ahd.zgrplist order by sym WHERE id = ?';
and
to
$sth->execute($test) or print "$DBI::errstr\n" and croak $!;
i am assuming that $test is a literal?
LVL 1
Author Comment
by:David Aldridge
Yes, $test is a literal.  I changed it to this and it does the same thing.
#!/perl -w
use DBI;
use DBD::ODBC;
use Carp;
$test = <@ARGV>;
my $SQL = 'select sym from ahd.ahd.zgrplist WHERE id = ?';
$dbh->disconnect();
LVL 13
Expert Comment
by:kawas
are you trying to read in files or a string of text representing the id you would like to query for?
LVL 13
Expert Comment
by:kawas
if just an id, try $ARGV[0]
LVL 13
Expert Comment
by:kawas
instead of <@ARGV>
LVL 1
Author Comment
by:David Aldridge
A string is passed to the script like so and these work:
test.pl WEBMETHODS ARCHITECTURE
test.pl SAP-BPI MAINTENANCE
This one breaks it:
test.pl Applications *** Internal Use Only ***
LVL 13
Expert Comment
by:kawas
okay.
2 things: get rid of the <@ARGV> statement and replace with $ARGV[0], and make sure that the strings that you pass into your script are enclosed in quotes if there is whitespace in the name.
LVL 1
Author Comment
by:David Aldridge
I thought that might get it... same results though.
LVL 13
Expert Comment
by:kawas
really? what errors are you getting now?
LVL 1
Author Comment
by:David Aldridge
Exactly the same.  If it doesn't have astericks, it gives me the right number from the database for the string passed to it.  With the astericks, it seems to pass the names of the files in the directory to the database as the query and it returns "not found".  Here is the exact error when I pass it "Applications *** Internal Use Only ***".
Applications Perl-1.pl test.pl test2.pl test3.pl wm_logwatch.pl working_hash_test.pl Internal Use Only Perl-1.pl test.pl test2.pl test3.pl wm_logwatch.pl working_hash_test.pl not found.
LVL 13
Expert Comment
by:kawas
I am not having the same problems. Could you post the script as you have it?
LVL 39
Assisted Solution
by:Adam314
Adam314 earned 1000 total points
When you say this:
    <@ARGV>
This means concatenate the arguments passed to the script, and do filename globbing on the results.  See here:
    http://perldoc.perl.org/functions/glob.html
You want to say this for your line 7:
    my $test = shift @ARGV;
Then maybe add something like this to line 8:
    die "Usage: $0 <search_term>\n" unless $test;
LVL 1
Author Comment
by:David Aldridge
Still gets the same results.
LVL 13
Expert Comment
by:kawas
can you post your script, because you shouldnt be getting the same results.
LVL 1
Author Comment
by:David Aldridge
#!/perl -w
use DBI;
use DBD::ODBC;
use Carp;
#$test = $ARGV[0];
$dbh->disconnect();
LVL 13
Expert Comment
by:kawas
how are you calling your script? can you show us that too?
LVL 1
Author Comment
by:David Aldridge
I'm just running it from inside of Komodo and adding the following as "Script Arguments":
'Applications *** Internal Use Only ***'
I've tried it with quotes, with double quotes, with nothing, and with the astericks escaped.
LVL 13
Expert Comment
by:kawas
try running the script from the command line. maybe komodo is doing some extra things for you
LVL 1
Author Comment
by:David Aldridge
Here's what I get from the command prompt.  Much more interesting information, but I still don't have a clue what to do about it.  :-)
C:\Test\logwatch>test3.pl Applications *** Internal Use Only ***
DBD::ODBC::st execute failed: [Microsoft][ODBC SQL Server Driver]Invalid character value for cast sp
ecification (SQL-22018) at C:\Test\logwatch\test3.pl line 20.
[Microsoft][ODBC SQL Server Driver]Invalid character value for cast specification (SQL-22018)
LVL 39
Expert Comment
by:Adam314
I'm guessing Komodo is doing the filename globbing.  Try running from the command line.
Or, if you want the script to ask the user to enter the id:
  Instead of:
  Try:
      print "Enter ID: ";
      my $test = <STDIN>;
      chomp($test);
LVL 39
Expert Comment
by:Adam314
The code you posted doesn't have a line 20.  Also, with spaces in the name, you'll need to put them in double-quotes in windows command prompt:
    test3.pl "Applications *** Internal Use Only ***"
LVL 1
Author Comment
by:David Aldridge
Here's line 20.
There reason that it went longer is I tried adding a regex to parse $text and remove the astericks and do a "LIKE" query by take "Applications%" and that didn't work.  I just removed that and here is the code I ran from the command prompt.  I tried it with the double quotes and got the same results.  Here are the results of running the attached code with the double quotes:
C:\Test\logwatch>test3.pl "Applications *** Internal Use Only ***"
ecification (SQL-22018) at C:\Test\logwatch\test3.pl line 16.
Bad file descriptor at C:\Test\logwatch\test3.pl line 16
#!/perl -w
use DBI;
use DBD::ODBC;
use Carp;
#$test = $ARGV[0];
$dbh->disconnect();
LVL 1
Author Comment
by:David Aldridge
Sorry, I didn't do a very good job of cleaning that mess up before I posted it.  I apologize. Here's the code that I am running right now and here's the error message:
ecification (SQL-22018) at C:\Test\logwatch\test3.pl line 14.
Bad file descriptor at C:\Test\logwatch\test3.pl line 14
#!/perl -w
use DBI;
use DBD::ODBC;
use Carp;
#$test = $ARGV[0];
my $DSN = 'driver={SQL Server};Server=SQLSERVER01;database=ahd;uid=reports;pwd=reports;';$SQL = 'select sym from ahd.ahd.zgrplist WHERE id = ?';
$dbh->disconnect();
LVL 13
Expert Comment
by:kawas
I think that your original question has been answered. the new problem is now based on your query. i havent used microsoft sql server, so i dont know what is wrong with your query...
not sure if this is possible, but you might want to try running the sql server client and trying your select statement with the asterisks in it. Might be easier to debug the statement that way.
LVL 39
Expert Comment
by:Adam314
Are you sure that is the exact code you are using?  Your $dbh isn't defined anywhere.
Does MS SQL have a query browser - some program where you can enter SQL statements, and view the results?  (I know MySQL has one, but I'm not familiar with MS).
If so, what do you get if you enter this:
    select sym from ahd.ahd.zgrplist WHERE id = 'Applications *** Internal Use Only ***';
LVL 1
Author Comment
by:David Aldridge
Here's the code and me running the code from the command line.  I'll pull up the client and see what I can come up with:
C:\Test\logwatch>type test3.pl
#!/perl -w
use DBI;
use DBD::ODBC;
use Carp;
#$test = $ARGV[0];
my $DSN = 'driver={SQL Server};Server=S02ASQLAHDPRD;database=ahd;uid=esm_rpt;pwd=Neptune01;';
$dbh->disconnect();
C:\Test\logwatch>
LVL 13
Expert Comment
by:kawas
#!/perl -w
use DBI;
use DBD::ODBC;
use Carp;
my ($id) = $sth->fetchrow_array();
print "$test" ."\'s USD group number is: $id\n";
$dbh->disconnect();
LVL 1
Author Comment
by:David Aldridge
When I run this in the client, it runs fine and pulls the number.  I did notice a mistake in my sql though as I was looking for the wrong field. I had sym and id reversed in my query.  I've added the corrected code but get the same results.  Here is the successful SQL statement I ran in the client:
SELECT     id
FROM         ahd.ahd..zgrplist
WHERE     (sym = 'Applications *** Internal Use Only ***')
#!/perl -w
use DBI;
use DBD::ODBC;
use Carp;
my $SQL = 'select id from ahd.ahd.zgrplist WHERE sym = ?';
$dbh->disconnect();
LVL 1
Author Comment
by:David Aldridge
I'm getting close!  I am actually getting the number back now, but can you tell me how to get rid of the this other error message?  It looks like it's just my complete lack of understanding how to use DBI.
Applications *** Internal Use Only ***'s USD group number is: 35580992
DBI::db=HASH(0x1a5c23c)->disconnect invalidates 1 active statement handle (either destroy statement
handles or call finish on them before disconnecting) at C:\Test\logwatch\test3.pl line 18.
LVL 1
Author Closing Comment
by:David Aldridge
I really do appreciate all of the help.  If I could award more points to you I would.  This was really important.
LVL 1
Author Comment
by:David Aldridge
I have attached the working code for MY future reference.  Thanks for all of the help!
#!/perl -w
use DBI;
use DBD::ODBC;
use Carp;
$sth->finish();
$dbh->disconnect();
Many time we need to work with multiple files all together. If its windows system then we can use some GUI based editor to accomplish our task. But what if you are on putty or have only CLI(Command Line Interface) as an option to  edit your files. I…
I have been pestered over the years to produce and distribute regular data extracts, and often the request have explicitly requested the data be emailed as an Excel attachement; specifically Excel, as it appears: CSV files confuse (no Red or Green h…
Explain concepts important to validation of email addresses with regular expressions. Applies to most languages/tools that uses regular expressions. Consider email address RFCs: Look at HTML5 form input element (with type=email) regex pattern: T…
Six Sigma Control Plans
Suggested Courses
580 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
