tupac1979
Need Help Finding an Imaging Solution or a solution to Ghost Lab Computers
We have just installed Red Hat Enterprise Server 5 and I wanted to know if there is a free imaging software solution to push images out to lab environments. Any help is appreciatted. Thanks
PXE boot works well with Windows if you've got a supported NIC and BIOS. I've never used g4u, but if you're familiar with imaging applications like Ghost, Clonezilla is similar. I'm not sure if its been changed much since I last used it, but server edition should work fine for your needs.
