I have two power supply that work but one doesn't power up the motherboard
The Galaxy 1000 W powers up my motherboard fine
I up graded to Koolance PSU-1300 ATX-12N it doesn't power my motherboard but I do get a green light
eathernet port so it is getting standbye light
I checked the wire pinout at both Power supplies and at the motherboard they are correct.
And really don't see any shorts around the motherboard
Dan1965Asked:
nobusCommented:
testing power supply: http://www.fonerbooks.com/power.htm
is your 4-pin (or 6, or 8pin) aux cpu power plug connected?   yellow/black wires
otherwise, it just may be dead - DOA
nobusCommented:
you can check if all voltages are present - following the pinout here :   http://en.wikipedia.org/wiki/ATX
Dan1965Author Commented:
just check yesterday voltage on both power supply correct Volts
both power supply work on different motherboard
Cloud Class® Course: Microsoft Office 2010
This course will introduce you to the interfaces and features of Microsoft Office 2010 Word, Excel, PowerPoint, Outlook, and Access. You will learn about the features that are shared between all products in the Office suite, as well as the new features that are product specific.
nobusCommented:
very strange; seems it can't handle the load
what is your setup? cpu's, ram disks ?  you could tes t with only 1 disk, 1 ram stick, 1 cpu
I wiil try 1 ram 1 Cpu
smiffy13Commented:
I recently had a case where the PC would power up intermittantly. I tested the power supply with one of these: http://www.newegg.com/Product/Product.aspx?Item=N82E16899705003 it indicated that the 5v was unstable, it varied between 4.8v and 5.2v. I replaced the psu which fixed the problem. I'm not sure how you tested your psu, I guessing one motherboard could accept a variation like this and another motherboard won't.
I used Rexus PST-3 Digital Power Supply Tester  for both power supplies
I will test them again
Koolance updated the There power supply  on +5 rails had some line noises that they fixed
That had trouble power up some motherboards
nobusCommented:
that's what i suggested :  " seems it can't handle the load"
WHAT HELP TO WAS THE FLOW CHART i BOUGHT IT RIGHT AWAY  THE LINE NOISE WAS CREATED BY MOTHERBOARD
THANK YOU
FLOW CHART WAS EXCELLENT
