Anjinsan5
Need pin outs for Power, switch, and HDD LED
I am putting my dell machine into a new antec case as the GPU is always overheating in the original Dell box since I put in a new radeon 3850 graphics card. I have managed around all of Dells oddeties and gotten the MB mounted. Now I just need to know where to connect the leads from the case for Power switch, HDD LED and Power LED. Naturally Dell is keeping this a secret. If anyone can tell me which of the pins are for what I would be really grateful.
do you know if anyone has made an adapter for the "front panel connector" that Dell uses rather than the standard jumpers that everyone else uses. I have tried attaching the leads from the case into the pins on the ribbon connector and they: #1: Don't seem to work and #2: don't stay on.
There is nothing standard from Dell, HP, or such manufacturing. If you can find similar system and check wire color codes and that would help you out.
Sorry I dont have Dimension here to check and suggest you more information.
Left led and right led are for the power and harddisk leds.
1-2 is power led, the green lead is + wire 3 to 5
6-7 is harddisk led, the red lead is +
8-9 is power switch, doesn't matter what way you connect.
