troubleshooting Question
Setting up 2 x Wireless Linksys/Cisco WAP4410N Connected on Same Network
Avatar of RTM2007
RTM2007Flag for Afghanistan asked on
Wireless NetworkingWireless Hardware
3 Comments1 Solution3712 ViewsLast Modified:
I have 2 x WAP4410Ns that I would like to span across 2 separated wide rooms. I would like for them to function both as 1 x SSID and so that where one hands off the other AP picks it up and so on.
Unlock 1 Answer and 3 Comments.
Learn from the best
Try for 7 days
-Mike Kapnisakis, Warner Bros
