troubleshooting Question
SharePoint 2003 Connected Web Parts Filter and Button Column Issue
Avatar of murphyge
murphyge asked on
.NET ProgrammingC#Microsoft SharePoint
1 Comment1 Solution453 ViewsLast Modified:
Premise: My web part page contains 2 web parts, connected via IRowProvider and IRowConsumer. The ButtonColumn on the Main Web Part provides the the row the Child Web Part. With a simple datagrid and ButtonColumn, this work perfectly.
However, to complicate things, I need to filter the DataGrid based on 4 DropDownLists. So by person, year, etc. The filtering works perfectly also. However, when trying to filter and then click the ButtonColumn, the SelectedIndex on the DataGrid remains at -1.
It looks like there is interference between the postback on the ButtonColumn and the DropDownList autopostback.
Where should I Bind the initial data and where should I then filter this data?
I have trimmed down the code for clarity.
protected override void CreateChildControls()
            base.CreateChildControls();
            base.EnsureChildControls();
            if (_serverName != "" && _databaseName != "")
                ddlPillarFilter.ID = "ddlPillarFilter";
                ddlPillarFilter.AutoPostBack = true;
                //Binds DropDownList
                ddlPillarFilter.Load += new EventHandler(ddlPillarFilter_Load);
                //Rebinds DataGrid Based on new Filter values
                ddlPillarFilter.SelectedIndexChanged += new EventHandler(ddlPillarFilter_SelectedIndexChanged);
                Controls.Add(ddlPillarFilter);
                dgData = new DataGrid();
                //Other Columns added here
                ButtonColumn selectionColumn = new ButtonColumn();
                selectionColumn.DataTextField = "projectid";
                selectionColumn.DataTextFormatString = "{0}";
                selectionColumn.ButtonType = ButtonColumnType.LinkButton;
                selectionColumn.HeaderText = "ID";
                selectionColumn.CommandName = "Select";
                dgData.Columns.Add(selectionColumn);
                //Binds Datagrid
                doPostBackOptions();
RenderWebPart(HtmlTextWriter output)
         output.WriteLine(........
         //Render Controls
Unlock 1 Answer and 1 Comment.
Learn from the best
Try for 7 days
-Mike Kapnisakis, Warner Bros
