troubleshooting Question
My c# applcation is gving build errors (An object reference is required for the non-static field, method, or property 'System.Xml.XmlDocument.Save(System.Xml.XmlWriter)')
Avatar of Loudninja
Loudninja asked on
Web Development.NET ProgrammingC#
2 Comments1 Solution626 ViewsLast Modified:
I am building a c# search application using visual studio 2008. I keep getting the following error:
Below is the code
namespace Search_application
        private void saveButton_Click(object sender, EventArgs e)
        //The following code saves the XML document to a file
            try
                SaveFileDialog sfd = new SaveFileDialog();
                sfd.Filter = "XML|.xml";
                sfd.FileName = "search.xml";
                if (sfd.ShowDialog() == DialogResult.OK)
                    FileStream fs = File.Open(sfd.FileName, FileMode.Append, FileAccess.Write);
                    XmlWriter writer = XmlWriter.Create(fs);
                    XmlDocument.Save(writer);
                    writer.Flush();
                    writer.Close();
                    fs.Flush();
                    fs.Close();
Unlock 1 Answer and 2 Comments.
Learn from the best
Try for 7 days
-Mike Kapnisakis, Warner Bros
