Start Free TrialLog in
Avatar of GlobexCorp
GlobexCorp
Shell script: How can I populate a shell script variable with result of sql statement
I want to populate a shell script variable with the result of a select count(*) sql statement. At the moment I can select the results and write them to a file but now I just want to get the count and populate a shell script varaiable with the value
i.e. I want the variable 'COUNT' to be populated with the result of 'Select count(*) from Table'
I'm a newcomer to shell scripting to so any help would be greatly appreciated
Avatar of mahome
mahome
Flag of Germany image
COUNT=3 or export count=3, if you want call other scripts which want to use it. If you post your exisiting script we can give more hints.
$ COUNT=3
$ echo $COUNT
Avatar of omarfarid
omarfarid
Flag of United Arab Emirates image
GlobexCorp
Thanks for the reply
I'm not sure of the username/password for the db, I'm working from someone elses code. I'm already accessing the DB so is there anyway of using that code without the inclusion of the user/pass?
I am not aware of any other method to access database without username and password
At the moment I'm successfully outputting a sql select to a file without using username/password:
'CODE=echo "select max(col) from TestTable where col like 'A%'" | ac_bl -qs -|  ~/developers/bin/runparallel -l20000 -n30","' >> Test_File.csv
I'm not using the user/pass here so I figured it was possible to read from the db the same way and instead of writing to a file populate my variable
I think either ac_bl or ~/developers/bin/runparallel has the username and password
