excel column unhide function does not work
excel column unhide function does not work.  It worked the last time I used this workbook.  It is not protected.
dparrot
dparrot
redrumkevCommented:
dparrot,
which column is not "unhiding" if it is A, try this:
http://www.experts-exchange.com/Software/Office_Productivity/Office_Suites/MS_Office/Excel/Q_23903942.html
Code attached below. If are unfamilar with macros, go to the link above, it explains how to insert a new module and then execute it.
Hope this helps,
Kevin
sub unhidea()
activesheet.range("A1").columnwidth = 15
end sub
Join & Write a Comment
Cloud Class® Course: Microsoft Office 2010
This course will introduce you to the interfaces and features of Microsoft Office 2010 Word, Excel, PowerPoint, Outlook, and Access. You will learn about the features that are shared between all products in the Office suite, as well as the new features that are product specific.
