Problem with Camera Control Pro 2 w/ Nikon D60
I have camera control Pro 2 v2.4.0. When I attach my D60, it says that the camera is not detected. However, windows detects it fine and allows me to do everything else with it with no problem. I saw other people fixed this by going to v2.3.0. I did that as well to no avail. Please help
zambuka42Asked:
lherrouConnect With a Mentor Commented:
Sorry, this one got away from me. Are you still having problems?
If not, can you post what steps you took to fix it?
If you are, how about trying Raymond Lowe's free tool for tethered shooting:
http://www.diyphotobits.com/category/download/
lherrouCommented:
zambuka42,
OK, some debugging questions for you:
1) Are you connecting directly or going through a USB hub? Make sure you are plugged in directly to a USB port on the BACK of your computer.
2) What Firmware version is on your D60? (Press the MENU button and select "Firmware Version" from the setup menu. The camera's firmware version will be displayed.) While there's been no firmware upgrade released for the D60, there are two different versions in the wild.
Cheers,
LHerrou
zambuka42Author Commented:
I am connected directly.. tried both usb slots. As for the firmware: A-1.00, B-1.01
The new generation of project management tools
With monday.com’s project management tool, you can see what everyone on your team is working in a single glance. Its intuitive dashboards are customizable, so you can create systems that work for you.
lherrouCommented:
And, just to verify, your camera is turned on when you are connected?
yes
Thanks for the link.. the original problem still exists though.
lherrouCommented:
Meaning you can't shoot with Camera Control Pro, or that you can't shoot remotely at all? If you can use the other program, then maybe we can sort out why CC Pro won't work.
ok, well, yes, the other program does work.
lherrouCommented:
So, we've established that the hardware (computer, cables, and camera ) is functional, but CC Pro simply won't detect the camera. Are you using Camera Control Pro v.2, or have you upgraded to 2.1? If not, get it here: ftp://ftp.nikon-euro.com/Software/kIQVSFTOnu/CCP21_EN.exe
i've got the lastest one.. like 2.1.40 i think
actually i have 2.4.0
lherrouCommented:
Oh, sorry... that's right 2.1 was the first that supported the D60, and the latest is 2.4.0 Hmm. OK, is your camera set, under USB settings, to PTP (not Mass Storage)? You can see the menus here: http://www.dpreview.com/reviews/nikond60/page12.asp
well, there's something... i don't have that option. However, i didn't see any firmware updates available either
lherrouCommented:
Try this: Go to the Set Up Menu (the wrench icon) and change "CSM/setup menu" to "Full" to see all the set up options. Then you should see the USB options, Mass storage or PTP.
That is the way it already is set.
