We've partnered with Certified Experts, Carl Webster and Richard Faulkner, to bring you two Citrix podcasts. Learn about 2020 trends and get answers to your biggest Citrix questions!Listen Now
sony vaio battery drain (never goes to full battery)
masterorb
masterorb asked
on
Last Modified: 2012-05-06
Hi,  I have a SONY VAIO VGN-SZ760N running Windows XP Service Pack 3.
I have done my best to avoid the dreaded memory effect with my battery. At first, I unplugged the computer as much as possible to use battery only so that the battery didn't get used to having power all the time. Then, I read that the best way to combat the effect was to just remove the battery and use direct power whenever possible, so I did that for a while.
Still, my battery has stopped lasting to its full potential. When I charge it (no matter for how long), it only goes up half way.
it lasts for about 2 hours.
There's a little switch on my computer (a physical switch above the keyboard) that says "Stamina/Speed" and I always keep it on "Speed." Not sure if that is important.
Watch Question
Explained the speed switch in your other post so wont go into it here but have you tried to discharge fully the battery and then recharging it fully
Sounds like it needs a cycle change so to speak and the only way to do this is to use the battery (without power) until it fully dies
My SZ4 is still going 2 years later and battery is fine but I do tend to use it 50/50 on battery and power as much as I can
Ask the Experts
I just realized--in "Battery Care Function" I have it set up for 50/50. I am going to turn that off, do what you suggest, and see what performance I get.
Thanks!
OR
Please enter a first name
Please enter a last name
