Donnie Walker
How do I solve IE6 / IE7 z-index layer problem with images?
I have a site here: http://www.kellercrescentdigital.com/babies/index.php?z=1 that has two image layers that overlap.
It looks good in FireFox 3 and Safari but the images are not properly stacked in IE6 and 7. Also my layer that says "Introducing Rylynn Jade" is not positioned right with those browsers.
How can I fix this?
How can I fix this?
#baby_frame {
position:absolute;
background: url("../images/bg_baby_frame.png") top left no-repeat;
width: 500px;
height: 600px;
z-index: 10px;
#baby_pic {
position:absolute;
top: 120px;
left: 50px;
z-index: -1;
#baby_name {
position: absolute;
top: 3px;
left: 20px;
width: 350px;
.bdetail th {
font-size: 12px;
color: #000;
text-align: right;
font-weight: bold;
.babydetails {
position: absolute;
top: 410px;
left: 195px;
width: 255px;
img.dogear {
position: relative;
top: -13px;
right: -13px;
float: right;
body {
background: #ffffff;
font: 12px Tahoma, Verdana, Arial, Helvetica, sans-serif;
margin: 0;
padding: 0;
color: #000000;
h1 {
color: #336699;
font-size: 15px;
padding: 2px 0 0;
h3 {
color: #000;
font-size: 27px;
margin-top: -5px;
margin-bottom: 15px;
h4 {
color: #000;
font-size: 17px;
margin-bottom: 0px;
padding-top: 5px;
#container {
width: 500px;
margin: 0px auto;
padding: 0px;
border:0;
th {
font-size: 9px;
color: #336699;
text-align: center;
font-weight: bold;
div.contentbox{
float: left;
background: #F7F7F7;
border: 1px dotted #ccc;
padding: 12px;
width: 473px;
margin-top: 20px;
I'm sorry, I forgot to comment on the #babyname DIV. You may also want to consider using padding to get those last few nudges just right. Try this:
#baby_name {
position: absolute;
top: 10px;
left: 20px;
width: 350px;
padding-top: 15px;
padding-left: 10px;
The px in div#baby_frame was a typo.
But the changes had no effect in IE6 or IE7.
I'm on IE7 in Vista and when I changed the positioning from the top to the bottom, it did move it. Albeit not very much, but it did take it off of the image. Did you try Ctrl+F5 to refresh IE?
Yes, but now the div#baby_name screws up in Firefox and Safari.
Safari looked fine
My main problem is IE6 and 7 and the stacking of the layers.
Negative values for z-index are not handled consistently cross-browser. I recommend you add a new <div> (as a child of #baby_frame) with the frame image as its background and position it on top of the photo.
Many elements have default padding and/or margins and browsers differ on their defaults for these. IE doesn't put a top margin on those headers by default while other browsers do. Simply specify values for the margins.
I recommend you read this: http://www.dynamicsitesolutions.com/blog/2008/12/10-things-you-might-not-know-about-using-css/
Kravimir, can you give me an example? I don't understand what you mean.
Thanks!
In regards to the DIV baby_frame, take the px off of the Z-index. Z-Index is a numerically based code and does not allow for pixels or percents.
http://www.w3schools.com/C
