[Okta Webinar] Learn how to a build a cloud-first strategyRegister Now
Solved
HP thin client does not get dhcp ip whereas laptop in same port, same cable does
Posted on 2009-02-18
Last Modified: 2013-11-09
Hi, We have a new thin client (WinCE 5.0) that wont pick up an IP address, but the same physical network connection to a laptop will. The thin client is set to dhcp and worked in the office before it was sent out. It is at a remote office on managed WAN. There are 8 other clients at the office that have no trouble (HP) getting dhcp, but most of them are fat clients and one is a HP thin client (t5525 or 5725 from iirc) running Linux and it has no problems.
Thin client is a HP T5530 Win CE 5
Between dhcp server and it is: dhcpserver->router->wan->router->hub->thin client.
If there is a way to fix this up remotely that would be great, otherwise it may work being manually set - I will travel out if so, but my worry is there is some incompatibility with the NIC in the thin client and dhcp over router hops or something like that?
Question by:cameronsaa
  • 3
4 Comments
LVL 2
Assisted Solution
by:dm7941
dm7941 earned 400 total points
If it was working in your office before you sent it out, a driver problem is unlikely.  I'd look for the obvious, like a disabled network adapter (either in bios or the OS). I'd say it's more likely that the copper connectors inside the network port on the thin client got bent or broken than some wild incompatability.
Please note that I can't speak much about winCE 5.0, so there might be some other stuff possible there.  I'm just speaking from general experience with the same type of problem on other types of devices.
Author Comment
by:cameronsaa
Thanks, its definitely not hardware related. I've been working through this issue with a staffer up there. Its not a disabled adapter. Another thin client plugged into the same port also doesn't get IP, but they both work in other ports. We tried setting it to static ip, tried reserving an ip on the server etc nothing.
As mentioned, laptops/fat clients plugged into this port also have no problems. I can't see how it could be anything other than an incompatibility, such as the one mentioned on HP website regarding Cisco switches and PORTFAST. There is a Cisco router in there, not a switch, but I'm guessing that port is configured differently to the others, as it seems to bother thin clients only, but laptops are ok. I'll check it out and get back.
Author Comment
by:cameronsaa
Ok, got a staffer to switch thin clients. Known good thin client also doesn't get IP from that port, but laptops still do. The thin client plugged into a different port has no problems, so I'm guessing a config on the connection somewhere in the chain is annoying the thin clients. I'm now trying to telnet the router but unfortunately the password hasn't been documented!
Accepted Solution
by:
cameronsaa earned 0 total points
Issue was the 10 year old hub/switch (NetGear Dual Speed DS116) / WinCE 5.0 combo - plugged that wall socket into a spare adsl modem/router/switch and plugged the thin client in as well, and its fine. Will be upgrading that hub pronto. Thanks for your help, dm7941
 The Evil-ution of Network Security Threats
What are the hacks that forever changed the security industry? To answer that question, we created an exciting new eBook that takes you on a trip through hacking history. It explores the top hacks from the 80s to 2010s, why they mattered, and how the security industry responded.
Hyper-convergence systems have taken the IT world by storm and have quickly started to change our point of view of how the data center should and could be architected. In this article, I’ll explain the benefits of employing a hyper-converged system …
This article will show how Aten was able to supply easy management and control for Artear's video walls and wide range display configurations of their newsroom.
In this video, Percona Director of Solution Engineering Jon Tobin discusses the function and features of Percona Server for MongoDB. How Percona can help Percona can help you determine if Percona Server for MongoDB is the right solution for …
In this video, Percona Solutions Engineer Barrett Chambers discusses some of the basic syntax differences between MySQL and MongoDB. To learn more check out our webinar on MongoDB administration for MySQL DBA: https://www.percona.com/resources/we…
872 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
