Solved
Urgently need help on building search engine
Posted on 2009-04-05
12
Last Modified: 2013-12-16
Having input text problems.
I've created the search form, results form and frame form. When i input any alphabet or number onto the textbox and click search, the outcome is not what i expected instead it shows all the results from the database table. What i want is that when i type anything, be it an number or an alphbet that is same to the data of a fieldname in rows(i.e 350v221, 350v265cc, a135vod etc..) inside the textbox, it will show the results of that particular files only. My database table have fieldnames like, DOC_NO (containing data of [i.e 350v000, 350v2587, 350v226 etc..]) [IN ROWS] ), DESCRIBE, REMARKS and STATUS. Also i got some tables that have many data (in number of rows) that consist of more than 20,000 information. My database table's name are saved as the starting number/alphbet (ie. 335a.dbm, 335b.dbm, 335c.dbm, 360V.dbm, wei.dbm, ght.dbm etc...). So is there any simple ways to query for these data? I've created frames so as to show the resulting page on the right frame and the searching page on the left frame. How do i link it together so as the results will show only on right frame even it get refresh?
Question by:alexanderax
  • 7
  • 5
12 Comments
LVL 16
Expert Comment
by:duncancumming
Just a word of advice.  You're usually better pasting your code as text, either in the main text box or in the 'Attach Code Snippet' box.  That way anyone answering your question won't have to manually retype anything.
Also "How do i link it together so as the results will show only on right frame even it get refresh?" is really a second related question.  The main question is just how do you get your query to work.
When you say
WHERE doc_no LIKE %#form.txtNumberInput#%
if the user types in say a  3, that will return all things where doc_no is like:
131
300
333
etc.  Basically anything with a 3 anywhere in it.  If you only want things that start with a 3, take off the first %
WHERE doc_no LIKE #form.txtNumberInput#%
That way you will only get things like:
333
300
etc
Author Comment
by:alexanderax
Thanks for your advice. Next time i will post it in the text. Anyway i'm not sure why i got error saying that txtNumberInput is undefined. Below the codes on snippet are abit different from the above as i just edited it. I still do not understand why i cannot get the outcome of it. Sometimes when i changed the code, there's no error but only that cannot get the output of the results that i expected.
Thank you for your help.
<b><!---Search_results.cfm---></b>
<CFset index="1">
<cfif not IsDefined("Form.txtNumberInput")> <!---If there's no input been type onto textbox, it will do the following code--->
    <cfquery name="get_FirstNo" datasource="DSN_db1_IWS">
     select *
     from 335v where doc_no like '%#form.txtNumberInput#%'
     order by doc_no
     </cfquery>
    <cfelseif IsDefined("form.txtNumberInput")>
    <cfquery name="get_FirstNo" datatsource="DSN_db1_IWS">
     select *
     order by doc_no
     </cfquery>
     <cfquery name="get_total" datatsource="DSN_db1_IWS">
     select *
     from 335v where doc_no not in ('abc')
     </cfquery>
</cfif>
    <cfif not IsDefined("form.ddlnumber")>
     select *
     from 335v where doc_no like '%#A#%'
     order by doc_no
     </cfquery>
     <cfif IsDefined("form.ddlnumber")>
     select *
     from 335v where doc_no like 'b%'
     order by doc_no
     </cfquery>
     select *
     from 335v
    </cfquery>
     <cfelseif #form.ddlnumber# is "Display Number">
     select *
     from 335v where doc_no like %#form.txtNumberInput#%
     order by doc_no
     </cfquery>
     select *
     from 335v
    </cfquery>
    </cfif>
<body bgcolour="A7EF92">
<table width....>
<tr>
<th width......>Number of files Generated:</br>
<font....><cfoutput>#get_total.qty#</cfoutput>
</table><br>
<table>
<tr>
<td...><font....>S/N</font></td>
<td...><font....>DOC_NO</font></td>
</tr>
<cfoutput query="get_FirstNo">
<tr>
<td align=""....>
<cfScript>
        writeoutput(index);
        index=index+1;
</cfscript>
</td>
<td.....><a href="../drawing search/searching.cfm?Doc_no=#'txtNumberInput'#" target="rightBottomFrame">#get_FirstNo.doc_no#</a></font></td>
<td....><font..>#get_FirstNo.DESCRIBE#</font></td>
<td....><font..>#get_FirstNo.STATUS#</font></td>
<td....><font..>#get_FirstNo.REMARKS#</font></td>
</TR>
</cfoutput>
</table>
</body></html>
<b><!---searching.cfm</b>
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<title>Searching</title>
</head>
<body bgcolor....>
     select *
     from 335v where doc_no like 'A%'
     order by doc_no
 </cfquery>
<cfelseif IsDefined("Form.txtNumberInput")>
     select *
     from 335v where doc_no like 'h%'
     order by doc_no
 </cfquery>
</cfif>
     select *
     from 335v
</cfquery>
     select count(*) as qty
     from 335v
     </cfquery>
<form action="search_results.cfm" method="post" target="rightBottomFrame">
<font>...
</font>
<input name="txtNumberInput" type="text" size="25">
<br>
</form></body></html>
LVL 16
Expert Comment
by:duncancumming
ok, firstly
txtNumberInput is an input type of text, right?  Even if you don't type anything in, and submit the form, this value will always be defined.  Just it'll be an empty string.  Change that line to
<cfif not Len(Form.txtNumberInput)>
Secondly, the query you have immediately after that relies on Form.txtNumberInput, which you thought wasn't even defined?  Not sure what you were thinking of there.  What really happens is
select *
     from 335v where doc_no like '%%'
     order by doc_no
i.e. it'll get every row in the table I think.
Don't bother with this.  WriteOutput is sort of deprecated these days.
<cfScript>
        writeoutput(index);
        index=index+1;
</cfscript>
There's a much easier way, just output #get_FirstNo.CurrentRow#
Free Tool: Site Down Detector
Author Comment
by:alexanderax
yes. txtNumberInput is specific as the (input name). I already edited the code but it still stated that i'm having error. ELEMENT txtNumberInput is undefined in form. error search_results.cfm: Line5
<cfif not IsDefined("Form.txtNumberInput")> Why is that so?
LVL 16
Expert Comment
by:duncancumming
Either your page has no Form struct, or you've maybe made a typo in the fieldname and there is no field called txtNumberInput in your Form struct.
Author Comment
by:alexanderax
What do you mean by fieldname anc? And how does form structure looks like? Can help me do my edit my code? Thanks for helping
LVL 16
Expert Comment
by:duncancumming
At the top of search_results.cfm, put this:
<cfdump var="#Form#">
That will output the entire form structure.  Does it include a field called txtNumberInput ?
Author Comment
by:alexanderax
I guess so. txtNumberInput is the name for user to input any text or number so that it will take that value and output on the results page.
Author Comment
by:alexanderax
what is the use of cfdump? when i type it on top of the search_results.cfm, it still having the same error. txtNumberInput is undefined in form.
LVL 16
Accepted Solution
by:
duncancumming earned 120 total points
So the cfdump didn't work, or did it output anything at all?  If so, what?
Instead of this line:
Try
<cfif not StructKeyExists(Form, "txtNumberInput")>
Author Comment
by:alexanderax
Sorry took quite long to reply. Last week i tried myself my own coding because i'm running out of time and i managed to get it myself. Can i change questions so that i can give you points? Below are the codes that i edited myself
<CFset index="1">
     select *
     from 335v
	<cfif #txtNumberInput# is not "">
	where doc_no like <cfoutput>'%#txtNumberInput#%'</cfoutput>
     	order by doc_no
	</cfif>
     </cfquery>
     select count(*) as CurrentRows
     from 335v
     </cfquery>
<meta http-equiv="Contecnt-Type" content="text/html; charset=iso-8859-1"><style type="text/css">
body {background-color=#A7EF9228bdee;
.style2{color:#b51111}
</style></body>
<table width....>
<tr>
<font....><cfoutput query="get_total"><b>#get_total.CurrentRows#</cfoutput>
</tr></th></table><br>
<table width...>
<tr>
<th width.....><font...>Search Results:</font></th>
<tr>
<td width...><font....>S/N</font></td>
<td...><font....>DESCRIPTION</font></td>
<td...><font....>STATUS</font></td>
<td...><font....>REMARKS</font></td>
</tr>
<tr>
<td align=""....>
<cfScript>
        writeoutput(index);
        index=index+1;
</cfscript>
</td>
<td.....><a target="rightBottomFrame" href="../drawing search/mainSearching.cfm?Doc_no=#get_FirstNo.doc_no#">#get_FirstNo.DOC_NO></a></font></td>
</TR></cfoutput></table></body></html>
<html>
<head>
<meta http-equiv="Contecnt-Type" content="text/html; charset=iso-8859-5"><style type="text/css">
body {
	background-color:#28bdee;
.style1{
	color: #9be094;
	font-weight: bold;
.style5{color:#C0D259}
.style6{color:#D1DE87}
.style7{color:#C7D76F}
</style></head>
<body class="sub"><br><br>
<font color....><span class="style5">&nbsp;<span class="style6"><strong>Document&nbsp;Number:</strong></span><br><br>
<font color="#FFFFFF"></font>&nbsp;&nbsp;
<input name="txtNumberInput" type="text" size="25" style="width:70%;"><br><br>
&nbsp;&nbsp;&nbsp;
<input type="Submit" Name="btnNumber" value="Display Number" style="width:70%;"><br><br>
<input name="btnReset" type="reset"  value="clear" style="width:70%;"><br><br>
&nbsp;&nbsp;&nbsp;<br><br></td></tr>
</table></form></body></html>
Author Closing Comment
by:alexanderax
Anyway thanks for your help
Free Tool: IP Lookup
Hi, I will be creating today a basic tutorial on how we can create a Mail Custom Function and use it where ever we want. The main advantage about creating a custom function is that we can accommodate a range of arguments to pass to the Function and …
Hi. There are several upload tutorials using jquery and coldfusion. I found a very interesting one here Upload Your Files using Jquery & ColdFusion and Preview them (http://www.randhawaworld.com/) . I did keep the main js functions but made sever…
The purpose of this video is to demonstrate how to integrate Mailchimp with Facebook. This will be demonstrated using a Windows 8 PC. Mailchimp and Facebook will be used. Log into your Mailchimp account. : Click on your name. Go to Account Setti…
The purpose of this video is to demonstrate how to prevent comment spam on a WordPress Website. This will be demonstrated using a Windows 8 PC. Plugin Akismet will be used. Go to your WordPress login page. This will look like the following: myw…
Suggested Courses
564 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
