Solved
document.body.style.cursor='wait'; does not work for me!
Posted on 2009-04-07
9
Last Modified: 2012-08-13
Hi, I used IE and FF but document.body.style.cursor='wait'; does not work, any suggestion?
Question by:Abdu_Allah
  • 4
  • 4
9 Comments
LVL 23
Expert Comment
by:apresto
Where are you calling this line? In a script or the event of a control?
LVL 11
Expert Comment
by:MacAnthony
You are going to have to give a little more context as to what is happening. Also any elements like text boxes or links and other elements that have custom hover styles over them will still change them to their respective style.
LVL 3
Author Comment
by:Abdu_Allah
I call it in a script.
The new generation of project management tools
With monday.com’s project management tool, you can see what everyone on your team is working in a single glance. Its intuitive dashboards are customizable, so you can create systems that work for you.
LVL 3
Author Comment
by:Abdu_Allah
I mean I call it in a function withing a JS script file and in the page I call that function.
LVL 23
Expert Comment
by:apresto
And you're sure that the code is being executed, put an alert("Test"); before the line is called, and see if it appears, you may have other js errors stopping it from executing
LVL 3
Author Comment
by:Abdu_Allah
Yes I'm sure and I did  alert("Test");
LVL 23
Accepted Solution
by:
apresto earned 750 total points
try putting a little delay:
setTimeout("document.body.style.cursor = 'wait'", 10);
see if that helps
LVL 3
Author Comment
by:Abdu_Allah
That works but why?
LVL 23
Expert Comment
by:apresto
sorry for the delay.
Honestly...i dont know, maybe its because it is giving the command a chance to execute before it performs anything else. The reason i suggested it is because it has helped me for similar things in the past
Glad i could help
Apresto
This article will give core knowledge of JavaScript and will head in to your first JavaScript program. I am Durvesh Naik and I am here to deal with this series of JavaScript. I will teach you JavaScript in part wise , as its quite boring to read big…
This article discusses the difference between strict equality operator and equality operator in JavaScript. The Need: Because JavaScript performs an implicit type conversion when performing comparisons, we have to take this into account when wri…
The viewer will learn the basics of jQuery, including how to invoke it on a web page. Reference your jQuery libraries: (CODE) Include your new external js/jQuery file: (CODE) Write your first lines of code to setup your site for jQuery.: (CODE)
The viewer will learn the basics of jQuery including how to code hide show and toggles. Reference your jQuery libraries: (CODE) Include your new external js/jQuery file: (CODE) Write your first lines of code to setup your site for jQuery…
Suggested Courses
601 members asked questions and received personalized solutions in the past 7 days.
Join & Ask a Question
