fr0x
Problem with input packet errors (WS-C2950G-48-EI)
Hello! I keep getting information on my switch port input errors, but cannot figure out, what kind of device is creating those errors. Is there any way to see on WS-C2950G-48-EI device, what device in ethernet network is sending error packets. I would like to see the MAC of the device. Is it possible for WS-C2950G-48-EI?
I can put *NIX/Windows PC box on the network, to check for errors from "inside", but then I have to know, what kind of software I have to use? Is there any packet sniffers on the net, which collects error packets on switched network?
Thanks.
Thanks.
ix10.ogre.oic.lv#show interfaces Fa0/27
FastEthernet0/27 is up, line protocol is up (connected)
Hardware is Fast Ethernet, address is 000d.bd3f.02db (bia 000d.bd3f.02db)
Description: brivibas22-switch
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 255/255, txload 1/255, rxload 1/255
Encapsulation ARPA, loopback not set
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 100BaseTX
input flow-control is unsupported output flow-control is unsupported
ARP type: ARPA, ARP Timeout 04:00:00
Last input never, output 00:00:00, output hang never
Last clearing of "show interface" counters never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 671000 bits/sec, 84 packets/sec
5 minute output rate 414000 bits/sec, 83 packets/sec
1526517221 packets input, 1914184066 bytes, 0 no buffer
Received 1391408 broadcasts (271322 multicast)
0 runts, 6 giants, 0 throttles
1116 input errors, 743 CRC, 367 frame, 0 overrun, 0 ignored
0 watchdog, 271322 multicast, 0 pause input
0 input packets with dribble condition detected
1222472371 packets output, 1163628669 bytes, 0 underruns
0 output errors, 0 collisions, 3 interface resets
0 babbles, 0 late collision, 0 deferred
0 lost carrier, 0 no carrier, 0 PAUSE output
0 output buffer failures, 0 output buffers swapped out
ix10.ogre.oic.lv#
What kind of equipments is connected to the port in your 2950 switch ?
Have you ever try to do a shut/no shut on fa0/27 ?
You can configure a span on your switch port to analyse the traffic which come through this interface with a basic sniffer. See what kind of traffic is generated...
(sorry for my multiple posts)
We have Repotec RP-1708K switch connected to 2950 switch port, and yes I tried to shutdown/enable fa0/27 port on 2950 switch. I even set manually speed - 100, duplex full, but this didn't help either.
Could you please write your last post more specific, I could try this option?! Thanks.
OK, I will look in Cisco document. Do you know, if even one error packet comes in Cisco 2950 port, it resets all mac-address-table for that port? Is there any option, where I could set not to reset arp table on input packet error on port?
Thanks.
Hum.. It seems weird... Didnt experienced this kind of problem sorry
